Old 15th March 2007, 12:52   #1
SCH
Default Clutch Plate change for Matiz
I have a December 1999 Matiz SD model and have clocked 84000 km. I maintain a strict service schedule every 5000km / 5months. ( which ever is earlier). The clutch plate being used is still original. I had a problem with gear shift cable which was replaced at 82000km. Is it suggested as a preventive maintenance I should get the clutch plate assembly changed.
SCH is offline   Reply With Quote
Old 16th March 2007, 17:47   #2
If your car is able to accelerate on steep hills without any problems, your clutch is fine. Don't bother.
amu1983 is offline   Reply With Quote
Old 16th March 2007, 17:59   #3
hvkumar's Avatar
Thanked: 3,365 Times
My Matiz original clutch plate failed at 110,000 kms. As long as you are a good driver, you should get that much. I think you can safely go along for least another 10-20,000 kms.
hvkumar is offline   Reply With Quote
Old 10th May 2009, 01:41   #4
sunil8089's Avatar
Thanked: 138 Times
Latest price for Matiz Clutch (PHC) in Chennai includinga. Clutch Plateb. Pressure Platec. Release bearing Rs.1950/-
sunil8089 is offline   Reply With Quote
Old 10th May 2009, 08:04   #5
goandude's Avatar
Thanked: 455 Times
Default prev maintenance
IMO a clutch plate would give ample and not critical warning of impending failure, like slippage or difficulty in gear change. thus preventive maintenance on this is not advised. also you have 10-20k more life left like mentioned above.
preventive maintenance in matiz at your running would be a timing belt change. if this item fails it ruins your engine. moreover it has NO warning of imminenet failure.
goandude is online now   Reply With Quote
Is this a clutch plate Problem???? The Stig Technical Stuff 15 2nd April 2012 09:29
Clutch plate goes kaput every 2-3 months amu1983 Technical Stuff 17 6th March 2008 13:30
Bullet Mag-wheels (size = 19") and 4-plate clutch assembly for sale wanderlustindia Shifting gears 0 27th December 2007 17:15
Is my clutch plate damaged? johy Technical Stuff 15 25th April 2006 07:20
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
