Old 19th July 2007, 19:20   #16
Ajaybiz's Avatar
Thanked: 142 Times
But u r not doing too much of extra reading as per your stock and after market tire size Difference in circumference is just 0.1%, so be relaxe and enjoy driving.
Ajaybiz is offline   Reply With Quote
Old 19th July 2007, 19:46   #17
Zappo's Avatar
Thanked: 2,080 Times
i do not think you need to loose to much sleep over this. actually the upsizing that you have gone in for makes a -0.1% difference in speedo display (odo is related, obviously). But then what does that mean? It means when your car speedo shows you that you are running at 100kmph your actual speed is 100.1kmph. Nothing meaningful.
Your odo again will report the same sort of error. For 1 lakh kms of travel it will show some 100 kms less. I guess you see the point here. Its not something worth bothering about.
There is also a small matter of speedo error which is there in almost all of them from day one. Most of the speedos show optimistic speeds by a fairly bigger margin. If anything this small under-reporting may actually help you get closer to the real figure. So rejoice.
Zappo is offline   Reply With Quote
Old 20th July 2007, 08:52   #18
hemanthisgreat's Avatar
thanks. i thought it was making a big difference. i did not know it was only 0.1%.
hemanthisgreat is offline   Reply With Quote
Old 20th July 2007, 15:08   #19
ajitkommini's Avatar
Thanked: 109 Times
Here is a handy tire size calculator: Tire size calculator
ajitkommini is offline   Reply With Quote
Old 20th July 2007, 17:06   #20
gemithomas's Avatar
Thanked: 138 Times
but what if we want to upgrade without looking at this calculation. Is it recommended provided it does not fault with the body even on full turns. In this case how can we ensure that the speedo is corrected. Any idea.
Old 20th July 2007, 17:48   #21
Zappo's Avatar
gemithomas, the question is not just that of whether the new tires foul with the wheel well. its a lot more intrinsic. you can not just upgrade to any size that you wish for. for that you need to know the rim size (diameter) and the pan width (in which the tube and the tire fits in). You also need to find out the section height of the existing tires. From this you calculate the total rolling radius (rim+tire) under the existing setup.
Once you know the rolling radius the idea is simple. Whatever setup you go for the total rolling radius needs to stay the same. So if you are upsizing (say 13" to 14") then of course the new tires that will go in will have lesser sidewalls (section height) to compensate for the bigger rim. The width of the tire is also important as depending on the pan width of the rim you got to decide this factor. Generally I think a 60% squeeze is ok. But anything more causes problem with the stability, tire life etc.
So you see, there is no running away from this maths. Thankfully for most standard tire setups readymade charts tell you the various combinations that will fit in. That is how I am sure even the great hemant got his new tires. His dealers would have suggested him the correct size. But it helps to have the understanding and the base clear.
Old 2nd July 2008, 12:00   #22
Thanked: 164 Times
Default Recalibaration of odometer for M800.
Hi, I have a 14 year old Maruti 800. In those days it used to come with bias ply tyres. But nowadays every one uses radials so I changed to radials. I.e. from 3.5-12 to 145/70 R 12. From the looks, it seems the radials are slightly lesser in height. My question is do you need to recalibarate the speedometer/odometer. I am tracking the fuel consumption closely for last 6 months and it gives me more than 19.5 kmpl. I drive mostly on the highways. So I am not sure it is the real number or the calibaraton error.
Thanks.
shipnil is offline   Reply With Quote
Old 2nd July 2008, 13:23   #23
gd1418's Avatar
Thanked: 656 Times
In my Scorpio of 2004 he stock tyres were Bridgestone duelers H/T 235x75R15.
I recently changed them after 70K kms to Bridgestone Duelers A/T 265x75R15 up size. While I know that the actual difference in speedo reading is +6 kms i.e. if the speedo is showing 100 kmph then actually it is doing 106 kmph, I would like to know the difference in the odo reading as that would help in calculating the FE.
At this moment, my FE readings are erratic although the vehicle is performing as before without any problem..
Old 3rd July 2008, 08:55   #24
recshenoy's Avatar
Thanked: 104 Times
Default Speed from gear box
Originally Posted by nitrous View Post
I just learnt that for a lot of cars, the speedo reading is taken from the Gearbox.
Eg. Baleno!
Small diversion from topic..
Guys please explain how the speed of the car is taken from gearbox.I mean the actual setup to get speed from gearbox.
Thank You
recshenoy is offline   Reply With Quote
Old 3rd July 2008, 13:21   #25
gd1418's Avatar
Thanked: 656 Times
Open the hood of the Esteem and trace out the end of speedo cable and see where it ends in the engine bay. You'll get a fair idea.
Thank You
Old 21st April 2011, 17:42   #26
Default Re: Odometer recalibration
Originally Posted by moralfibre View Post
The Palio odometer is electronic, i.e. there is a sensor at the wheel which relays information to the ECU and which in turn conveys information to the speedometer. I doubt whether any recalibration is possible.
Can some one plz point the exact location of the ODO sensor ?
which wheel has the odo sensor ,
my palio 2002 , 1.2 odo meter numbers and trip meter stopped working ,
the needle for KMS works fine .
if u can post a pic it would be a great favour .
thanks
octane_fx is offline   Reply With Quote
Old 21st April 2011, 22:39   #27
dhanushs's Avatar
Thanked: 4,506 Times
thanks
Hey octane_fx, its the speedo sensor at the wheels/gearbox.
In your case, as speed is still shown, I guess the mechanism which connects the speedo>odo>trip meter is damaged in the console, and not a sensor issue.
Highest reading in the odometer! Surprise The Indian Car Scene 602 18th April 2018 19:39
Cars with 7 digits on their odometer (over 1 million kms / miles) supremeBaleno The International Automotive Scene 18 31st March 2016 19:40
Odometer Reading: How to tell if it has been tampered with? nd81 Technical Stuff 58 8th September 2011 21:18
Can this odometer be repaired? tsk1979 Technical Stuff 12 21st March 2007 03:17
Which odometer is correct? hasopi The Indian Car Scene 8 14th October 2005 08:47
