| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| Hi Guys, One of my friends has a Ford Ikon Sxi 1.6(2004) which has covered 50K. The car is having some weird issues- One fine day the radiator system gave up and Burst, Got that changed, The advisor also said that the Alternator needs to be changed ( He explain why and My friend just paid up), Then Sometime later the Ignition Coil was replaced and after all this- He now is having Delayed Start in the mornings ( For an MPFI car I think its quite unheard of) and Even with 10- 15 Selfs the car refuses to start, He drives down to South City Ford-Where all the other services have been done and The Advisor claims Something is wrong with one of the Cylinders..What could it be guys..! and Just incase the Diagnoses is correct for the cylinder, What all will be done to the Engine..! No Check Engine Error. Regular Service. Self-Driven.
__________________ " When was the last time, You did something for the first time " Last edited by wolfinstein : 18th March 2007 at 11:08. |
| | #2 (permalink) |
| Senior - BHPian | Problem with one of the cylinders...wht does he mean by that..and how does he come to such a conclusion...Ignition coil is a problem with all ikons..iam getting used to it now...my ikons ignition coil has been changed for the 2nd time.....Delayed start..could you describe more on this...Could be the starter..
__________________ 2008 DRIVERS CHAMPIONSHIP - LEWIS HAMILTON 2008 CONSTRUCTORS C'SHIP - McLAREN MERCEDES |
| | #3 (permalink) |
| Says First Cylinder is showing lower compression,But no loss in power or pickup when running. Starter and Ignition coil have been changed..!
__________________ " When was the last time, You did something for the first time " |
| | #4 (permalink) | ||
| Distinguished - BHPian ![]() Join Date: Feb 2005 Location: Mumbai-India
| Quote:
I wont be surprised if they have changed good parts with bad one during fixing your radiator.
__________________ Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap. | ||
| | #5 (permalink) |
| But if the fuel line is choked, The supply would be restricted to all the Injector would'nt it..! I also suspected one of the Injectors, He is on his way to the Center as I write...So Will let you all know what service center has now advised..!
| | #6 (permalink) |
| Ok here is the latest, The service center says the Head will be changed for the Engine, 2 bolts required, Head Gasket..! Can someone list me where can i source spares for the Ikon..! @ Arush- I don't have the address for your garage, Is it possible to come meet up for the case. Anything else that can be done..!
| | #11 (permalink) | |
| Quote:
| | #12 (permalink) | |
| BHPian | Quote:
![]() Good one elf!! I'd second that!! -Absar
__________________ Ford Ikon 1.6 Nxt ZXi, 2005 I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM. Last edited by Absar : 19th March 2007 at 21:49. | |
| | #13 (permalink) |
| Also ask him to do a compression test in front of you & if possible take a mechanic with you who knows about engine & compression test. @ELF thats the first thing he should do... LOL
| | #14 (permalink) |
| Distinguished - BHPian ![]() | Has a compression test been done on each of the cylinders? There is no way compression in one of your cylinders could be bad, as in that case you will have the car not pulling smoothly when the engine is cold. Check for contamination of colant in your engine oil dipstick in the morning. My guess is that it is not going to be so. Try simple injector cleaning.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #15 (permalink) |
| Lol..! I really wish the poor guy had done that long ago..! Apparently there are only two Ford service stations in Delhi- This one being South City Ford. The Head is found to be damaged and is opened up at the workshop- Current estimate is Close to 40 k, I have suggested my friend to take a second opinion..! Yes he drove around 20- 30 kms without coolant, The radiator burst happened in Gurgaon and The needle for Temp C did not rise until he was parking at his home in Saket, After that he drove with Water to the Service Station. Got the Radiator replaced, Coolant and Alternator was adjusted and Thermostat was changed ( Alternator was not changed as mentioned earlier). Now lets see what happens ahead...! BTW can a head be repaired in any case ? The Only surprise is that the Car runs fine, Just the way Josh machine should..But when it does not crank in the mornings with a Cold engine...It becomes a Joke Machine
__________________ " When was the last time, You did something for the first time " Last edited by wolfinstein : 19th March 2007 at 22:40. |
| Thread Tools | |
Similar Threads | ||||
| IKONic problems | danlalan | Technical Stuff | 76 | 28th September 2008 11:03 |
| One last drive, those iKONic moments. | Jaggu | Long-Term Ownership Reviews | 22 | 7th July 2008 12:14 |
| M800 Troubles... | doomsday | Technical Stuff | 16 | 14th September 2007 13:04 |
| Xeta troubles: Faults and faultier! | phamilyman | Long-Term Ownership Reviews | 14 | 13th September 2007 01:26 |
| Hyundai India's troubles-Business Today Article; May 8, 2005 | Revvmaster | The Indian Car Scene!! | 20 | 6th May 2005 09:50 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
