Old 19th March 2007, 13:48   #1
tsk1979's Avatar
Thanked: 16,421 Times
Default Can this odometer be repaired?
My Indica's odometer has developed a strange problem at around 75K kms.
when the trip meter(the small meter at bottom) reaches 99, it does not go beyond that. At that point the main odometer also refuses to go forward. So for the main odometer to register kms I have to reset the trip meter every time its about to reach 99.
Can this problem be repaired, or the entire console has to be replaced etc.,
The Speedometer works fine. Its of pricol make(I guess all indica's have pricol meters).
Old 19th March 2007, 14:19   #2
ramie2400's Avatar
Thanked: 58 Times
If your Indica is under warrany period you may get it replaced by the TATA service center.No idea about the repairs of the Odometer bro.
Old 19th March 2007, 14:22   #3
nitrous's Avatar
Thanked: 285 Times
There must be a meter specialist in Delhi who can help U.
But these days, everyone suggests replacement rather than repair.
Old 19th March 2007, 14:27   #4
tsk1979's Avatar
My indica is out of warranty by a long margin, its a 2002 model, about to complete 5 years in another couple of months or so.
If somebody knows of a meter specialist in Delhi, it will be great.
Old 19th March 2007, 14:32   #5
esteem_lover's Avatar
Thanked: 451 Times
Meters can be repaired. Have done this umpteen number of times for the bike. But you will never feel the same after that. There will always be that feeling that the speedo or the odo is just not right. Better get it replaced.
Old 19th March 2007, 14:55   #6
khanak's Avatar
Thanked: 130 Times
what happens when the odometer is replaced? do you start from 0 again?
khanak is offline   Reply With Quote
Old 19th March 2007, 14:58   #7
navdeep's Avatar
surely that will be from zero itself but I am not sure if you can alter the readings without breaking the seal.
navdeep is offline   Reply With Quote
Old 19th March 2007, 15:00   #8
abdriver2000's Avatar
Thanked: 24 Times
I faced the same problem with my bike, a couple of weeks ago. I got it repaired, just one spring needed.
A new console would have cost me 1050.
abdriver2000 is offline   Reply With Quote
Old 19th March 2007, 15:03   #9
Thanked: 24 Times
The seal is nothing but a small sticker over one of the screws. Some people maintain extensive logs of their cars/bikes. I have always added the kms when getting the odometer serviced. That way, I try and maintain an accurate reading.
Most people do the opposite. I know of a friend who sold a 2lac kms car after resetting it to 40000.
Old 19th March 2007, 15:13   #10
navdeep's Avatar
.. but many people prefer not to open a new one unless there is some obvious reason mentioned above.
Old 20th March 2007, 11:42   #11
Hi
You can TRY your luck with the People who REPAIR CAR RADITORS, thats what I was told of by MARUTI guys.
Tnx N Rgds
P4C
passion4cars is offline   Reply With Quote
Old 20th March 2007, 12:01   #12
tsk1979's Avatar
Latest update, just the trip meter has gone mad the ODO is fine.
So will ask the TASS guys about this, if they say replace whole console, will go to a local repair guy.
Old 21st March 2007, 03:17   #13
Why dont you check in the local GUJRI? definately there is a good hassle free(!!!)deal(with a possible exchange deal) in the corner.
P.S:It is reccomended to ask your(trusted Mechanic/driver)to handle it.
Desert fox is offline   Reply With Quote
Leaking Dampers (Shock Absorbers) : Can they be repaired? pranav_mankad Technical Stuff 32 29th August 2017 01:30
Are alloy wheels prone to damage & can't be repaired? shapath Tyre & Alloy wheel Section 95 5th July 2017 14:43
Can the turbo be repaired? The_Warrior Technical Stuff 17 6th February 2015 22:16
A request to all the audio gurus .. Can this be repaired ?? mclaren1885 In-Car Entertainment 38 13th July 2006 13:21
can a moulded bumper be repaired. pankaj09 Modifications & Accessories 15 30th March 2005 17:17
