Old 24th November 2007, 15:33   #31
Ram
Ram's Avatar
Thanked: 149 Times
Originally Posted by BUSA View Post
Hey GTO, Can you please share with us, where you got the button start done and how much did it cost you?
Originally Posted by S@~+#0$# View Post
BUMP!! BUMP!!
I am thinking of getting a Push-button switch for my Esteem. Has anyone got this conversion done? How reliable is it?
Friends, this is the most trivial of electrical mods, if one wants to call it that. All we're doing is shunting part of one switch with another switch.
The simplest of key-switches has a terminal that receives power from the battery (usually a red wire).
Then it has terminals for ignition-on and starter-engage, and optionally one more terminal for accessories.
All the other terminals are either additional accessories, ganged with ignition-on or with accessories.
Now it is the simplest thing in the world to wire it as follows.
case1:
or as follows.
case2:
In case 1, you will have your own custom exclusive push button start button.
In case 2, you can have your an additional custom push button start button, in addition to the spring-loaded key start.
Just do it yourself. It will be as reliable as the push button switch you use and the quality of wire-terminations in your workmanship.
The old CJ-2A Jeeps (split-windshield), used to have a foot operated starter switch, like the foot operated dipper switch.
Ram
Ram is offline   Reply With Quote
Old 24th November 2007, 15:40   #32
S@~+#0$#'s Avatar
Thanked: 37 Times
Thanks Ram, as always your pictures + explanation leaves little/no questions in our minds. I'll try doing it myself.
S@~+#0$# is offline   Reply With Quote
Old 24th November 2007, 16:15   #33
dustDevil's Avatar
Ram, in the above cases won't we be able to crank the car (though it won't start) even if the ignition is turned off! Can't we bifurcate a wire to the starter button from the ignition terminal? That way the sarter wouldn't work unless the ignition is also functional. Just a thought!
dustDevil is offline   Reply With Quote
Old 8th December 2007, 23:45   #34
BUSA's Avatar
Thanks for the detailed explanation. Really helpful and kind of you.
What is the procedure for push-starting a car?? Deeps Technical Stuff 29 24th December 2014 15:28
Push Button Start / Ignition jesal Modifications & Accessories 114 28th July 2013 12:18
Santro automatic : What is the use of the OD (overdrive) button? subscrive Technical Stuff 5 1st August 2010 15:25
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
How far can they push a common platform approach? rangaraj The Indian Car Scene 11 12th February 2008 14:20
