Old 21st March 2007, 17:39   #16
mobike008's Avatar
Thanked: 8,319 Times
As suggested a 1200gsm paper should do the job. And dont worry chetu, these days the paints we get are of so high quality, you wont know the difference.
Old 21st March 2007, 19:04   #17
elf
elf's Avatar
Thanked: 9 Times
Once again, do not do this yourself. Go to a known workshop, not necessarily authorised by the manufacturer. But trusted by you, nevertheless.
elf is offline   Reply With Quote
Old 21st March 2007, 20:08   #18
Surprise's Avatar
Thanked: 272 Times
I too had this problem in my Swift (Black). Got rid off it by wax polish. Also you can go through the below threads to get an idea
http://www.team-bhp.com/forum/techni...d-paint-2.html (How to remove unwanted paint?)
http://www.team-bhp.com/forum/techni...r-paint-3.html (paint over paint)
Surprise is offline   Reply With Quote
Old 21st March 2007, 23:39   #19
subbarp's Avatar
Thanked: 80 Times
Default After Shave
Originally Posted by sreedotk View Post
Get a small bottle of Nail polish remover and try to rub it out. It usually works well with the wall distemper kind of paints, with enamel i am not so sure. Also if it does work make sure you get your car waxed really well after removing the paint stains
If there are no ladies around (or are possesive about their nail polish remover!), the after shave can be used. It works pretty well to remove the very fine cement dust that settles on cars if they are anywhere close to construction sites. This is easily available and does not create a mess, and on top of it, you come out smelling better rather than worse.
subbarp is offline   Reply With Quote
Old 22nd March 2007, 00:34   #20
elf
elf's Avatar
Thanked: 9 Times
You guys gotta be kidding!
DO NOT use aftershave / acetone / nail polish remover under any circumstances.
Old 22nd March 2007, 11:41   #21
Chetu's Avatar
Thanks elf and mobike008. i will get it done based on ur suggestion.
Chetu is offline   Reply With Quote
Old 22nd March 2007, 15:00   #22
Thanked: 2,469 Times
Hey Man,
Simple try kerosene moistened cloth and the enamel paint will come off soon.
Old 1st April 2007, 15:14   #23
spatafarose's Avatar
U can get the stains off by having it rubbed with a good rubbing compound. It wont cost you more than 100 rs. But because its white cement stain, You better take it to a good place where you get your car painted. Guys there could help you out.
spatafarose is offline   Reply With Quote
Old 2nd April 2007, 05:02   #24
chetu!
the only safe way is 'cutting' like elf has already suggested.followed by rubbing,polishing and buffing.
get this done by a professional.
also try 3M's 'finesse it!' its a microfinesse finishing compound.use it on a small spot and watch those spots vanish.
tell us when you have your car gleaming again!
doctorkats is offline   Reply With Quote
Old 2nd April 2007, 12:40   #25
Chetu's Avatar
Originally Posted by doctorkats View Post
chetu!
Thanks doctorkats, I do enquired at one of the Maruti authorised service center. He said the same as you mentiond with 3M rubbing and polishing the job can be done. looks like he's going to remove the stains from thinner first later he applies 3M rubbing and polishing. is this the right method to do or not?
Old 3rd April 2007, 21:16   #26
elf
elf's Avatar
Thanked: 9 Times
Originally Posted by Chetu View Post
... looks like he's going to remove the stains from thinner first later he applies 3M rubbing and polishing. is this the right method to do or not?
For God's sake, read the posts above man! DO NOT apply thinner to your paint under any circumstances.
Old 3rd April 2007, 21:22   #27
Jaggu's Avatar
Thanked: 8,674 Times
goto 3M and fix it, if its paint it will come off.
and avoid experimenting yourself with thinner and all coz they can be bigger head aches.
Please help..Stains on Chrome on My Bullet panky12345 Motorbikes 31 29th August 2016 15:14
HELP Urgent : White water stains on the windscreen nanu28 Technical Stuff 13 3rd March 2015 09:32
Help - removing kumkum stains on new car! maheshshanmugam Technical Stuff 17 7th September 2014 21:27
How to remove oil stains??? sidd_city Technical Stuff 9 8th October 2008 18:26
How to remove sticker stains from windshield? akash_m Technical Stuff 3 25th January 2008 11:07
