Old 21st March 2007, 14:19   #1
SCH
Default Plastic Noise from Dashboard.
I experience a plasticky noise from the dashboard of New Honda City. The noise goes if I out a hand over the left hand side, above the glove box of the dashboard . pls. sugest remdies as the service center people are unable to give a solution.
SCH is offline   Reply With Quote
Old 21st March 2007, 14:56   #2
theMAG's Avatar
Thanked: 1,572 Times
Could it be because the dash IS made of plastic? Or are you refering to a resonance sound from the dash in sync with the engine speed?
Old 21st March 2007, 15:14   #3
benbsb29's Avatar
Thanked: 4,277 Times
Is it possible that something in the glove compartment is making that noise?
benbsb29 is online now   Reply With Quote
Old 21st March 2007, 15:24   #4
mobike008's Avatar
Thanked: 8,319 Times
I thought dashboard noise is inherent only to Hyundai's. Even i face this noise problem once in a while on highways which is a cause of big irritation.
I noticed that this happens due to items not kept properly in the dash and if i rearrange them properly the noise disappears.
Old 21st March 2007, 15:27   #5
navdeep's Avatar
just empty the glove for a day .. and check if the noise persists..
navdeep is offline   Reply With Quote
Old 21st March 2007, 19:06   #6
rishibravo's Avatar
If emptying out doesnt work try stuffing the glove compartment such that you have to apply some force to close it . I am not joking. It worked on my old 800 but didnt make much of a difference as there were 10 other things in the car making rattling sound
rishibravo is offline   Reply With Quote
Weird noise from dashboard when starting the car RocketRaccoon Technical Stuff 6 8th December 2015 14:08
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
If I want to change Vista Dashboard to Manza dashboard: A Discussion sushantr5 Modifications & Accessories 14 13th July 2010 12:08
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
