Old 1st April 2007, 14:28   #16
Ricky_63's Avatar
Thanked: 377 Times
Hi
Thanks for the reply. I have read the thread by SAP & he surely knows what he is talking about......my problem is the availability of these hub centering rings......do you happen to know where they are available in Delhi / Gurgaon ?
Old 1st April 2007, 14:48   #17
spatafarose's Avatar
i also had this problem.. It can be made okay by doing the following:
1. Wheel Balancing
2. Wheel allingnment
3. Steering overhauling
spatafarose is offline   Reply With Quote
Old 1st April 2007, 17:56   #18
Ricky_63's Avatar
Thanked: 377 Times
1. Wheel Balancing
Hi
Mine is a relatively new car with 20 k on the odometer.......Wheels are balanced, allignment is ok, steering does not require an overhaul, as it is in perfect condition.....my problem is purely what I mentioned (hub centering rings)
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
What is better for driveability : 0-100kmph OR 20-80kmph? shantyrocks The Indian Car Scene 91 27th March 2009 20:41
Wagon-R abnormal noise above 100kmph abhishek79b Technical Stuff 19 27th November 2008 16:16
Class Starts Early; Indigo CS launched; starts at 3.79lac jkdas The Indian Car Scene 208 28th May 2008 18:53
Pulsar 180 sluggish after 100kmph member Motorbikes 6 23rd August 2006 22:51
