| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| Newbie Join Date: Nov 2007 Location: pune
| Kpzen Sir, Good day to you. Thank you for explaining the tyre terminology with calculations.All doubts cleared. Also can you please tell me by how much one can increase the rim size say from 13 inch to 14 to 15 taking into account that the tyres wont touch the wheel arches ?How to decide on that and gain max ground clearance for a given car. Naj |
| | #17 (permalink) |
| Team-BHP Moderator ![]() | Naj, this link has a handy calculator. You can also use the article in advice section Car Bibles : The Wheel and Tyre Bible Page 1 of 2
__________________ Reclaiming.....! |
| | #18 (permalink) |
| BHPian | Stock Tire - 175/70R13 -------------Tire 1 - 175/65R14 Section Width: 6.88 in 175 mm ----Section Width: 6.88 in 175 mm Rim Diameter: 13 in 330.2 mm ----Rim Diameter: 14 in 355.6 mm Rim Width Range: 4.5 - 6 in ----Rim Width Range: 4.5 - 6 in Overall Diameter: 22.64 in 575.05 mm ----Overall Diameter: 22.95 in 582.93 mm Sidewall Height: 4.82 in 122.42 mm ----Sidewall Height: 4.47 in 113.53 mm Radius: 11.32 in 287.52 mm ----Radius: 11.47 in 291.33 mm Circumference: 71.12 in 1806.4 mm ----Circumference: 72.09 in 1831.0 mm Revs per Mile: 918.7 ----Revs per Mile: 906.3 Actual Speed: 60 mph 100 km/h ----Speedometer1: 59.1 mph 98.6 km/h Speedometer Difference: - Speedometer Difference: 1.368% too slow Diameter Difference: - Diameter Difference: 1.36% courtesy Tire Size Calculator - tire & wheel plus sizing
__________________ Honda City Maruti ZEN - SOLD Maruti 800 Bajaj Pulsar Last edited by sushrutha : 11th December 2007 at 13:31. |
| | #19 (permalink) |
| Newbie Join Date: Feb 2008 Location: Visakhapatnam
| I got a Maruti SX4 Zxi recently. I don't like the high ground clearance(ride height) and want to lower the suspension a little bit(around 15mm) to make the car look more aggressive and sporty. I want to know if lowering kits are available in India or if not where do I need to go to get it done. Something like shorter suspension springs etc would be fine. I know I can decrease the ground clearance a bit by using low profile tyres but I want to lower the ride height by reducing the wheel well height. I would like to know if any sport suspension kits like lowering springs and matching shock absorbers are available in India and also if they are specific to the car model you own. Any names of reputed brands available in India would be a help. For example the SX4 Sedan which was launched in America uses sport suspensions to bring the ride height down by around 10mm compared to the SX4 crossover which sits a little higher than the sedan. Any decrease in ground clearance of 10-25mm would be commendable as I might further lower the car in the future by going for lower profile tyres. Also does anyone know if this is a simple job which can be done in any automotive garage shop or if this is a complicated process and is done in only big cities like Bangalore, Chennai etc? |
| | #20 (permalink) |
| BHPian | Check with BHPian Turboindia (Peter) or at Pete's Automotive Products Pvt Limited He maybe able to help.
__________________ Into each life some rain must fall Last edited by itwasntme : 6th August 2008 at 15:49. Reason: Typo |
| | #21 (permalink) |
| Distinguished - BHPian ![]() | Suspension lowering is merely an word-of-mouth term for it, dharmana! It is no doubt a complicated process. And it comes with a high probability of writing-off the design and relegating a worthy car to the wild and wacky thread! Granted there are east Los Angeles low-rider clubs that tinker with this sort of thing, but bear in mind ... ...that they use bolt-on, factory-made, after-market components that have gone through rigorous engineering design by real automobile/aircraft designers. Often, these are designed to exceed the specifications of the OEM components they are substituting. And the base platforms modded by these clubs are strong X-frame 1963-67 rear-wheel-drive Chevrolet Impalas -- not bottom of the food-chain Japanese econoboxes, which were never purposed for longevity, anyway! In the process details are: Detailed study of the engineering drawings -- the tolerances -- suspension travel -- danger of bottoming out -- fabrication of custom suspension components -- guarantees, to handle the stresses you will put on the crate -- okaying by regulatory bodies ... A very good strategy for you could be to import the lowering kit meant for the Suzuki SX4 sedan (USA or Canadian version). You have to work with a qualified professional (let's call him an automotive architect) who designs cars for a living. Very few such people are found in India, to the best of my knowledge and will be fairly expensive. They will have access to a great deal of expensive equipment, and a very well equipped factory with static and dynamic measurement instruments. Your expenses can end up, somewhat more than simply importing a readymade production-line Corvette or Porsche or Italian sports job, for instance. Beware of desi cosmetic modifiers (so called screwdriver street mechanics) who can't even take accurate measurements, nor make drawings worthy of marks in a qualified professor's scrutiny, leave alone handle automotive design software. They are invariably mentally-challenged as far as appreciating the safety and handling consequences of their tinkering. Bear in mind that the final outcome may not pass professional inspection. It's the difference between going to a super-specialty cardiac surgeon and going to a beachside masseur or witch-doctor, for crying out loud. Ram
__________________ On Google Chrome 0.2.149.27 since Tue. 02-Sep-2008. When you struggle for something and fail, that’s when you get Experience! |
| Thread Tools | |
Similar Threads | ||||
| Issues regarding ground clearance of CIVIC | Vishesh | The Indian Car Scene!! | 46 | 20th November 2007 18:51 |
| Ground Clearance of Opel Corsa 1.4 | abhayk_in | Modifications & Accessories | 0 | 19th November 2007 13:44 |
| Increasing ground clearance | pathfinder | Modifications & Accessories | 11 | 15th December 2006 04:03 |
| NHC ZX - Ground Clearance | venkatrx | The Indian Car Scene!! | 14 | 18th August 2006 17:25 |
| Improving the Ground Clearance | naveendhyani | Modifications & Accessories | 1 | 17th March 2006 09:08 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
