Old 22nd September 2009, 12:33   #31
sgiitk's Avatar
Thanked: 3,884 Times
Mods. Is not the title a bit of a misnomer.
Be careful of the stated ground clearance for a car. This is the height of the lowest part of the car above the ground. Almost invariably it is the steering linkage between the front wheels. This point due to its location will ride up and down with the vehicle as it goes over a bump. So is almost irrelevant as far as the car hitting the tarmac is concerned. What will hit the ground is something else - exhaust, or mid body. This may also depend on how soft the suspension is. So do not take the GC figure as the truth, in practice it will be something else which will matter!
sgiitk is offline   (1) Thanks Reply With Quote
Old 22nd September 2009, 14:13   #32
shankar.balan's Avatar
Thanked: 5,350 Times
thanks for this input!
now the Scorpio has a GC of 180mm
the Bolero I think has 200mm
Gypsy has 210mm
As far as I know the lowest bit of my Scorpio is the differential gear housing at the rear of the vehicle. Is this correct or not?
I ve taken all these vehicles off the tarmac a number of times and have been able for the most part to drive over several obstacles etc, without any parts bottoming out.
I am however very careful over our "home-made desi" speed breakers owing to their height and lack of proper banking etc.
Await your further inputs
Thanks!
Old 22nd September 2009, 14:51   #33
sgiitk's Avatar
I was writing in the context of fwd 2-wheel drive vehicles, i.e. modern day cars. With the Scorpio what you say is very much possible. Just check the bottom of the sump and/or steering linkages and compare. Remember I stated 'almost' .... almost expecting what you raised!
Old 22nd September 2009, 16:25   #34
Thanked: 90 Times
Totally agree! It is to do with the designing of the vehicle where the lowest points are in line with the front or the rear wheels, giving in reality a much better GC.
scooby05 is offline   Reply With Quote
Old 22nd September 2009, 17:13   #35
Thanked: 30 Times
Infractions: 0/1 (5)
My Wagon-R Lxi with stock tyres used to scrap every desi speadbreakers, But after changed them to 155/70/R13 CONTINENTAL tyres, GC has been increased by 8mm now. I am pretty much happy now and i easily avoid the scrappings on the same speed breakers(the same driving style over them with 5 on seat). This calculation helped me to choose 155/70 profile.
GC of Wagon-R Lxi (165mm)
145*0.7 = 101mm (Stock) 165mm
155*0.7 = 108mm (conti) 165+7=172mm now
155*0.6 = 100mm (Michelin) Lowered by 1mm
Jebs is offline   Reply With Quote
Old 10th November 2012, 10:41   #36
Default Re: Ground Clearance
So what happens when the company itself provides different stock tyres in the in the different versions of the same model. For example, the stock typre on Etios G is 175/65/R14 and on Etios V is 185/60/R15. Now the diameter different between the two is 20 mm and therefore a huge 10 mm difference in height. However the company states the GC of all versions as 170. So, does it mean that they make changes for the G or V version (in suspension or whereever) to keep 170mm GC in both versions or in reality there would be a difference in the GC of the two versions?
Kaboooooom is offline   Reply With Quote
Optimum ground clearance of a Car? & how it is measured... skamb Technical Stuff 84 17th May 2017 22:36
Raising a Tata Marina's Ground Clearance vivek.singh.73 Modifications & Accessories 27 8th September 2013 21:43
Issues regarding ground clearance of CIVIC Vishesh The Indian Car Scene 92 12th July 2011 13:49
NHC ZX - Ground Clearance venkatrx The Indian Car Scene 17 30th July 2009 20:22
NHC Zx Ground Clearance and Ride quality mahesh4sure The Indian Car Scene 8 24th February 2006 11:39
