Old 25th May 2010, 19:59   #46
Shan2nu's Avatar
Thanked: 89 Times
Most road cars use wide gear ratios, so it doesn't make sense skipping gears while upshifting, unless you've achieved a good enough speed in the lower gear.
On my OHC, i always make sure the gear im shifting into gets the engine speed to a min of 2000rpm on a flat surface. If it's an incline i increase this rpm to 2500-2700.
Someone driving a turbo diesel could get away with doing 2000rpm even on an incline. So how/where you shift will change with the transmission and engine characteristics of your car.
Shan2nu
mp3 skipping problem sourav21 In-Car Entertainment 27 9th November 2010 10:53
CD's Skipping? Whose fault is it & how to find out! greenhorn In-Car Entertainment 23 7th March 2010 18:54
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Is CD skipping a problem ( KENWOOD KDC-MP5039U ) ? vikrant1982 In-Car Entertainment 1 9th December 2008 18:55
