Old 22nd April 2009, 15:10   #16
Thanked: 252 Times
Originally Posted by siddartha View Post
, if you start the engine and then check the dipstick the oil would have splattered all over the length of the dipstick, so you wont be able to tell correctly up to what level on the dip stick oil is there.
There is a method to it, LOL.
You wipe the dipstick clean and very rapidly insert fully and withdraw it.
Old 22nd April 2009, 15:13   #17
abhibh's Avatar
Thanked: 33 Times
Originally Posted by supremeBaleno View Post
However if you are paranoid, you could use the dip stick to confirm whether the oil level is between the upper and lower limits marked on it.
What if the level is above the upper limit ?
Old 22nd April 2009, 15:51   #18
siddartha's Avatar
Thanked: 22 Times
wow! i hope you have patented this novel method.
siddartha is offline   Reply With Quote
Old 22nd April 2009, 15:56   #19
esteem_lover's Avatar
Thanked: 445 Times
Exactly !!
I am sure the manufacturers did not mark the dipstick for checking with the engine running.
Old 24th April 2009, 18:16   #20
alexnazim's Avatar
What do additives do when added to the engine oil? I am thinking of shifting to Castrol GTX Magnatec and I believe ti is 10W-40. I plan to flush the existing oil the normal 15W-40 and add fresh Castrol Magnatec. How will that affect in terms of engine noise/performance/cold starts?
alexnazim is offline   Reply With Quote
What happens to the engine oil when the Oil cap and/or dipstick is opened? D.V.R Technical Stuff 29 19th September 2016 17:35
Mark Webber alright after a heavy crash at WEC Sao Paulo zenren Int'l Motorsport 0 1st December 2014 21:28
How to check if Fuel Injectors are alright? extreme_torque Technical Stuff 4 28th July 2006 10:00
