Old 26th March 2007, 19:08   #1
Default Esteem engine oil : is 3.5ltrs alright?
According to manual engine oil capacity is 3.3ltrs but my mechanic poured 3.5ltrs in it. Will it be alright or shall i get .2ml out
max8791 is offline   Reply With Quote
Old 26th March 2007, 23:39   #2
nitroxx's Avatar
Thanked: 26 Times
relax bro no issues with 3.5ltrs ok?
nitroxx is offline   Reply With Quote
Old 27th March 2007, 13:39   #3
supremeBaleno's Avatar
Thanked: 1,635 Times
Well, it would be darn tough to remove just 0.2ml. What you should be trying is to remove 0.2litre.
Jokes apart, as nitroxx said, there should not be any issues with that extra 0.2l inside. However if you are paranoid, you could use the dip stick to confirm whether the oil level is between the upper and lower limits marked on it.
Old 27th March 2007, 13:42   #4
akroy's Avatar
Thanked: 29 Times
No issues with that extra 200ml....You can check the level with the dipstick...
Abhi
akroy is offline   Reply With Quote
Old 27th March 2007, 22:36   #5
hmm thank you all for comments.. will check the dipstick tommorow
Old 21st April 2009, 19:35   #6
alexnazim's Avatar
Will the 200ml make any difference if I am shifting to Mobil 1 Synthetic oil along with a new oil filter?
alexnazim is offline   Reply With Quote
Old 21st April 2009, 19:43   #7
alexnazim's Avatar
What is the esteem engine oil type anyways? Is it 15W 50 or 10W 40??
Old 21st April 2009, 21:32   #8
vigsom's Avatar
Thanked: 581 Times
15W40,20W40,20W50
don't worry - 200ml extra will not do any harm.there is ample allowance in the sump to take in that much Extraaaaaaaaaaaaaaa
Old 22nd April 2009, 11:46   #9
HKS
HKS's Avatar
I don't think synthetic oil user should worry about the rating of the oil required.
HKS is offline   Reply With Quote
Old 22nd April 2009, 13:47   #10
siddartha's Avatar
Thanked: 22 Times
if you engine is healthy then there will be no problem , but if its an old engine which is past its prime condition, and if the compression is poor due to worn piston rings etc , putting extra oil may end up fouling the spark plugs.
siddartha is offline   Reply With Quote
Old 22nd April 2009, 13:52   #11
Thanked: 252 Times
That is certainly not true!
Best way to confirm oil level is to start the car and then check the dipstick. Level should be below maximum. If so, you're OK. It's not good to overfill to the extent of having the conrods 'slapping' the oil in the sump!
Old 22nd April 2009, 13:58   #12
nitrous's Avatar
Thanked: 282 Times
Why is the start needed?
Old 22nd April 2009, 14:06   #13
Thanked: 252 Times
Oil level seen on the dipstick will always be less with the engine running as there will be oil in all the lines and bearings.
The idea is to make sure that with engine running, the conrods do not 'slap' the crankcase oil!
Old 22nd April 2009, 14:17   #14
siddartha's Avatar
Thanked: 22 Times
firstly i am not listing methods of checking oil level.
secondly , i am talking from an experience that i have had .
lastly , if you start the engine and then check the dipstick the oil would have splattered all over the length of the dipstick, so you wont be able to tell correctly up to what level on the dip stick oil is there.
Old 22nd April 2009, 14:29   #15
sgiitk's Avatar
Thanked: 3,755 Times
While Synths are no doubt good one should still respect the higher viscosity index since this is what matters when the engine is hot. If the spacifications call for SAE40 when hot I would be loathe to use a SAE30 oil, synth or not!
What happens to the engine oil when the Oil cap and/or dipstick is opened? D.V.R Technical Stuff 29 19th September 2016 17:35
Mark Webber alright after a heavy crash at WEC Sao Paulo zenren Int'l Motorsport 0 1st December 2014 21:28
How to check if Fuel Injectors are alright? extreme_torque Technical Stuff 4 28th July 2006 10:00
