Old 27th March 2007, 23:55   #16
condor's Avatar
Thanked: 4,895 Times
Originally Posted by Wheeliej View Post
But i use a light hand on the hand brake
This would be the way to use the hand brake .. Most people I have seen, pull the hand brake ALL the way up - without leaving any play to be used when releasing the brake.
Old 28th March 2007, 10:59   #17
elf
elf's Avatar
Thanked: 9 Times
... Most people I have seen, pull the hand brake ALL the way up - without leaving any play to be used when releasing the brake. ...
Especially valets & parking-lot attendants. They think it's an excuse for gymming.
elf is offline   Reply With Quote
Old 28th March 2007, 11:11   #18
Default Handbrake Issue
from you problem it seems the CABLE is the culprit.
in most of the cars: HAND BRAKE works on rear wheels, secondly on most models there is no seperate handbrake pads as many people have mentioned.
handbrake uses regular service brake shoes in rear to engage.
if it is sticky , try it:
start your car, release hand brake lever, push & relese service brake pedal 2-3 times, if it is the problem in service brakes it will probably get released , if it still sticks, hand brake cable needs replacemnet/lubrication
before arriving at bigger problem like service brake jamming always start chekcing from step by step , in you case the problem arised with use of hand brake, so try finding fualt first there.
get braking system cheked, cleaned at every 20k kms.
Arun
arunforu1 is offline   Reply With Quote
Hand Brake - Do you use it everytime ? mithun Technical Stuff 111 24th June 2015 10:07
Blaring Music + Bad Driving = Does it go hand in hand!!! SamtheLeo Street Experiences 77 20th December 2014 20:41
Hand Brake Operation revharder Technical Stuff 25 14th February 2010 12:42
Wise decision-First hand car or second hand car Surprise Hatchbacks 51 4th October 2009 20:04
