Old 27th March 2007, 14:49   #1
Default Coil Indicator Blinking On My Skoda Octavia
Hi guys Help is required on my skoda octavia diesel
usually when i start the car the coil blinks for couple of seconds and goes off as soon as the engine is on, but sometimes while on the move if i stop the engine and immediately turn it on again then the coil indicator starts blinking continously ..........it has happened with me no. of times .....in this case everytime i have to stop the car for few minutes then the light goes off.infact with the coil blinker the engine oil light also comes on.....
can u tell me what can be wrong ?
i showed it to my dealer (silvertone) , they changed the brake fuse and said the problem wont come back coz it was related to the brake fuse but its still there.....
i hope this problem is not damaging anything else in my car....
please help
autozoniac is offline   Reply With Quote
Old 27th March 2007, 15:00   #2
Rtech's Avatar
Thanked: 221 Times
If you stall the car and start it up immediately without first turning the ignition in the "off' position, the glow plug indicator starts to flash. Nothing to worry about. Simply turn the ignition off for a few seconds and that solves the problem.
P.s. it says this in the manual as well.
Old 27th March 2007, 17:46   #3
gbpscars's Avatar
hi
what does this coil indicator or glow-plug indicator do?
gbpscars is offline   Reply With Quote
Old 27th March 2007, 17:52   #4
Rtech's Avatar
Thanked: 221 Times
A glow plug indicator is a warning light that lights up when you first turn on the ignition. It basically pre-heats the combustion chambers in order to allow the fuel to combust upon compression.
You basically wait a few seconds for the glowplugs to heat up. When the dashboard light turns itself off, you can start the engine. Though on the Skoda, the glowplugs never really get used (atleast not in the south) as it never gets cold enough.
Old 27th March 2007, 18:22   #5
gbpscars's Avatar
So we are talking diesel here. yes?
Thanks for the info Rtech.
i can read a more on this now.
Troubleshooting a fast blinking indicator cryshnon Technical Stuff 1 11th July 2016 23:47
Maruti Esteem Check Engine Light Blinking amitpunjani Technical Stuff 10 12th November 2012 16:41
Help required for PS3 - Blinking red light & lens cleaning Akshay1234 Gadgets, Computers & Software 18 17th October 2011 14:27
Swift automatic climate control - blinking 'auto' sjohn Technical Stuff 11 14th November 2010 21:39
amplifier stops working when vol increased! light blinking! althaaf In-Car Entertainment 5 16th September 2009 23:15
