Old 28th March 2007, 23:50   #1
Unhappy RPM doesn't return to idle soon
I got my Santro erlx March 2006 model serviced yesterday ... a very strange problem has come up and I really don't know why it should come up just after getting it serviced ... as per the service advisor the car was in great shape and nothing wrong with the car
The car starts normally and rpm increases during starting and goes back to idle in 2-3 secs ...
Once I am on the move and press the accelerator and release it the rpm does not return to idle immediately it takes 2-3 seconds and its approximately as high as if AC is on whereas the AC is off ...
I tried searching for other RPM related issues in the forum but they were mostly about erratic idle ...
Here it is slightly different the rpm once they return to idle it stays there till i press the accelerator and release it ...
Something like the following happens without AC
800 rpm -> press accelerator ->2500 rpm -> release accelerator ->1100 rpm -> delay of about 2 secs -> 800 rpm
Any help is very well appreciated ...
dj_2006 is offline   Reply With Quote
Old 29th March 2007, 08:54   #2
rdkarthik's Avatar
Thanked: 11 Times
Get the throttle cable adjustment and sensor position checked... It is okay for idle to take some time to get back to normall, but 2-3 seconds is on the higher side.
rdkarthik is offline   Reply With Quote
Old 29th March 2007, 18:29   #3
Lukeskywalker's Avatar
Thanked: 1,170 Times
This happens in my Santro too, though I do not have a tacho, but can hear the whine of the engine even as i lift my foot off the throttle, or depress the clutch completely while in motion, sometimes I feel like I don't need to press accelerator at all, as the engine RPM goes high.
Lukeskywalker is offline   Reply With Quote
Old 29th March 2007, 18:46   #4
Jaggu's Avatar
Thanked: 8,686 Times
check your cable and get your throttle body serviced
Old 1st April 2007, 15:01   #5
spatafarose's Avatar
This happens to Santro.. I had this problem. Actually its not a problem. You could get used to it. I had this issues with some Matiz also. May be cars with fuel injection have this prob. But if it takes more than 2 seconds you have to take your car to an Authorised service centre and check that. It can be dangerous sometimes.
spatafarose is offline   Reply With Quote
Old 1st April 2007, 17:01   #6
deep_bang's Avatar
Thanked: 343 Times
My santro too had this problem. I have sold the car now, but i think it is the way the ECU manages the engine.
My theory is that Santro "learns" a little as we drive and adjusts some parameters. I had tried an experiment of removing the battery connections and plugging them back. After doing this, the "2 second" problem was no longer there - but only for about 200 or 300 kms. It came back again. So, i am thinking Santro stores some parameters which gets reset when the battery connections are removed.
deep_bang is offline   Reply With Quote
Old 2nd April 2007, 01:03   #7
chetanhanda's Avatar
Thanked: 44 Times
yes could be ...
but lets guess what parameter the ECU is trying to mantain by not dropping the revs to 800 quickly again .. ?
chetanhanda is offline   Reply With Quote
Old 2nd April 2007, 01:16   #8
Thanked: 294 Times
i think it is normal occurence in santro....but one can try removing the battery to reset the ecu....but one thing I dont think this removing the battery would make much of a differnce...
Old 2nd April 2007, 06:22   #9
goldsun's Avatar
Post
I had this in my ALTO earlier and I think it is not an issue. For me, this happens when the engine is cool and when the engine runs for a about 5 to 10 minutes, then this behaviour disappeared. But I always keep my AC on.
goldsun is offline   Reply With Quote
Old 2nd April 2007, 15:06   #10
I havent tried removing battery connections.
Old 2nd April 2007, 15:57   #11
nispatel's Avatar
When I switched to a new Santro 8 months back from Carb M800 and carb Esteem, I found it very annonying that it take a while for RPM to come down even after releasing accelerator and fully depressing clutch. This was ending up as not so smooth gear shift. Visited Advaith service station couple of times and everytime they explained that this normal behavior of the car.
Untill recently I was thinking that it's because of MPFI engine. Now since many members are experiencing same issue, I am coming to the terms that this *is* the way Santro behaves.
nispatel is offline   Reply With Quote
Old 4th June 2007, 19:34   #12
AvinashKeezh's Avatar
Unhappy Erratic RPM on the Ikon 1.6 (ROCAM Engine)
I have this problem with my 2005 1.6 Ikon. It's been like this for quite some time now.
Start engine -> 2000 rpm, it keeps up there for a long time.. i asked the authorised guys, and they say it's because of petrol from diff vendors... i don't know how true that could be... haven't been able to spend time on it all this while. thought i'd check out the forum, but looks like we don't have this problem on a large scale. I tried the mech's advice, filling almost 3-4 tank fulls from the same vendor (SHELL in blore). and haven't been able to find any difference. in fact its like the car has a mind of it's own, it comes back to normal without much fanfare and goes up all of a sudden too..
anybody with an idea on what could be the problem..
shall try the battery disconnect option once, and post asap...
but in the meanwhile if someone's had this prob, and had managed to get it solved, please do post..
AvinashKeezh is online now   Reply With Quote
Old 4th June 2007, 19:50   #13
shonn1's Avatar
Get your throttle body cleaned. It will solve your problem.
shonn1 is offline   Reply With Quote
Old 4th June 2007, 20:04   #14
Deepz's Avatar
i have a 2001 santro ( 1 litre engine) , have had these issues with rpm too.. i had mentioned this to the service station on 3 consecutive services..but nothing could be done about it, so i've just made my peace with it now.. anyways, its not too frequent also, how often does it happen with the rest of you guys?
Deepz is offline   Reply With Quote
Old 4th June 2007, 20:19   #15
Could be sticky throttle plates, ISC etc. do a scan and tell Ford to rectify this, also spray some carb cleaner in your intake tract, and add some STP Fuel Injector cleaner to your gas.
Gurkha is offline   Reply With Quote
If it doesn't challenge you, it doesn't change you! EPMV Introduce yourself 7 30th March 2016 12:17
Vibrations in Baleno at all times (Low varying Idle RPM) rohanmeets Technical Stuff 8 25th February 2008 11:36
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Baleno Idle Rpm shobhit15 The Indian Car Scene 13 24th October 2005 22:40
How to reduce the Idle RPM Suryam Modifications & Accessories 4 19th February 2005 17:16
