| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jul 2006 Location: Pune
| My Indica V2 is around 3 years old. I had to do a 20 KM run around 2 weeks back in the afternoon. Almost at the end of my journey, the engine died off. I could not get it to start even with a "dhakka start". Nothing seemed to happen. Luckily there was a battery showroom nearby and the person helped me out. He said that if one of the cell in the battery stops working (short ho gaya), then the circuit is broken and hence the engine died off too. Surpirsingly, with his other battery in place, the car started applying the first starter. Question: Is this logically correct? Can this happen? I was asked to change the battery ASAP since this could happen during every long run when the battery starts heating up due to charging. |
| | #2 (permalink) |
| BHPian Join Date: Mar 2005 Location: Mumbai
| That sure is scary. What the battery guy told you could be right. Just to get a better understanding of things, I guess the battery in your car was the original OEM battery (which came with the car). Tata uses good sources such as Exide? Secondly, a start engine should not die as the alternator would be providing sufficient current even under idling, unless there is a problem with the alternator. Better get your electrical system checked up when you replace your battery. |
| | #3 (permalink) |
| Senior - BHPian | a problem i faced was that the car would refuse to start. the fault was traced out to a loose electrical wire to the heater element. i had the battery replaced et al, but to no effect. I suggest you get your electricals checked, as I dont think 1 cell "shorting" would cause the battery to die. It would have started with a push start as well if the battery had drained out.
__________________ Blah!! __________________ 2002 Lancer | 2006 Palio | 2008 Trek 4300D |
| | #6 (permalink) |
| Senior - BHPian | Similar thing happened with me in Scorpio, though the engine did not die while driving. One evening I visited my relatives and the beast started at half crank at home and reached the destination with all HLs blazing and the strobes on. In the middle I had to go to pik up some stuff and that's when the ordeal started. It wouldn't start at all. As soon as the key was turned to start, the lights would dim. Scorp started with a push and then we went home. The next day morn when I wanted to take it to garage again it didn't start; even with a jumper cable..!!! Again push started and drove to garage. A cell of the battery had gone kaput. Replaced with a new battery and all ok. The ineteresing thing that the battery guy said that this is a typical problem of all batteries that come in plastic casing. If one cell goes weak or fails the battery simply dies down unlike in the traditional batteries where a weak battery would still labour to crank the engine. Any comments..???
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx Last edited by gd1418 : 4th April 2007 at 11:56. |
| | #7 (permalink) | |
| Quote:
Need expert comments on this please. What are possibilities of this happening on a new battery? | |
| | #15 (permalink) | |
| Senior - BHPian Join Date: May 2006 Location: Chennai
| Quote:
The engine dies as soon as i remove one terminal..Thats when i realised that engines with electronic ignition have this problem. The only solution would be to change the battery and drive!!![]()
__________________ Storm ing the Roads!!! | |
| Thread Tools | |
Similar Threads | ||||
| Car in the middle of the road totalled by Bus | herculesksp | Street Experiences | 85 | 21st February 2009 11:42 |
| Long term shutdown | turbofreak | Technical Stuff | 3 | 18th July 2007 15:34 |
| BOOM and shutdown | humyum | Technical Stuff | 6 | 7th May 2007 19:32 |
| Indica Xeta LPG or Indica Turbo Diesel?? | nobreaks | Hatchbacks | 12 | 2nd September 2006 00:29 |
| diesel indica | vandan | Shifting gears | 3 | 22nd March 2005 19:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
