| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Aug 2006 Location: Bangalore
| My Previous post was about Sun glare issue with Ford Ikon Dashboard. Thanks for suggestions on that - though I haven't yet arrived at some working solution....A different problem with the car this time My Ford Ikon 1.6 Zxi Petrol is 12000km run. While slowing down and shifting from 5th/4th/3rd gear to 2nd gear (of course with clutch fully depressed), the engine stalls sometimes. It happens very randomly. When the engine stalls, clutch is still fully depressed. Have got the spark plugs cleaned twice and petrol filter cleaned, didn't fix it. The issue doesn't happen while going up-slope, happens with AC On or off - doesn't matter; doesn't happen during shifting gears UP, happens only during shifting gear down. Service guy says battery is OK and battery can't cause this problem; I'm using Bharat Petroleum Normal (no SPEED) petrol from same petrol pump for last 6 years. Any suggestions? Change petrol? But wondering my other car Santro has no issues with same petrol. Garage guy says ECM needs to be checked for electrical issues. Or fuel injection pipes need to be checked for blockage. If nothing helps, ENGINE inspection is needed. Haven't consulted Ford Dealer, since in Bangalore, their service is nothing less than pathetic. - RK |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | Sounds like your fuel mixture is too lean or breather pipes from inlet manifold are leaking or idle sensor valve faulty. A Bosch car service centre may assist From your avatar, I believe you occasionally get chased by a madman in a bellowing black Honda Vtec or a blue blinged swift who works in the same company. That madman is me - I believe we share a common friend whose first name is the same as yours
__________________ I love the whoosh, but i miss the bellowing |
| | #3 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| go with Ajmat's suggestion, looks like a vacuum leak or idle setting issue
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #6 (permalink) |
| i defer psych's, atleast i saw car shunt and switch off while fiddling around at ford shop ![]()
| | #7 (permalink) |
| Update on Ford Ikon 1.6 Engine stall problem: I got it fixed. This update may help somebody if he sees the same problem. After few visits to local garages I finally decided to contact Metro Ford, Bangalore. My friend recommended to email Metro Ford customer care. I did. Suprise, they actually responded by email and then on phone! No solution on phone, they asked me to visit their workshop next day. The reviews I read about Metro Ford were never good. So, I was cautious. I reached Metro Ford and asked for the guy whom I was supposed to get in touch with. This guy listened to my problem for 5 min. Next he sat in the driver seat and reached out for a plug just over clutch which he said was disconnected. He said it is a clutch sensor and it was disconnected. For a min, I thought this guy is crazy, because if the clutch sensor is disconnected, how was my car running all these days. And it was the 4th or 5th time I was showing it to the garage guy. Nobody else could find it out earlier? I had got spark plugs cleaned twice, fuel filter cleaned, vacuum leak checked. My next thing to do was to get ECM checked and this guy was telling me that clutch sensor was disconnected! Anyway, I had no option than to trust him. With a mixed and confused feeling, I left Metro Ford. That is the end of story. The issue hasn't happened again. Was it really so trivial a problem? I was ready to get ECM scanned and do anything Ford guy would have asked me to do, since it was very irrirating a problem and had to be fixed. Good job from Metro Ford! Interestingly the guy who fixed the issue was not a workshop engineer. He was the guy who attends to customers and makes the job card. More importantly, I didn't pay anything to Metro Ford - RK |
| | #8 (permalink) |
| great to hear car problem is solved, and if you have read my review of metro ford, they are tricky that all but ok guys, and the guy whom you spoke to should be an service advisor/engineer, usually they are the ones who take the car in clutch sensor this i didnt knew off, might be something to do with the engine rpm thingie with clutch activation, guessin still doesn matter as long as she is purring..
| | #10 (permalink) |
| BHPian | Searched a lot to get some topic like this. Thanks all..i have the same problem with my car and i will try that out tonight and see where it goes. But one thing i have noticed is that this problem happens only when the engine is cold. Not on the way back home from office when the engine is quite heated up. Any chance the problems can be same? or is it something different i should look in to? |
| Thread Tools | |
Similar Threads | ||||
| For Sale: Ford Ikon 1.6 zxi | brraj | Shifting gears | 6 | 23rd November 2007 15:37 |
| Ford Ikon 1.8 ZXI Diesel for Sale | throttleking | Shifting gears | 0 | 29th October 2007 16:54 |
| Ford Ikon 1.6 Zxi 60000km review | BunnyPunia | Long-Term Ownership Reviews | 16 | 31st May 2007 16:34 |
| Ford Ikon - SXI Bumpers for ZXI | gr8guzzler | Modifications & Accessories | 13 | 30th June 2005 18:36 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
- RK
