Old 28th September 2007, 07:08   #286
chetanhanda's Avatar
Thanked: 44 Times
Originally Posted by madan80 View Post
Found this add on the forbes website.
Depends on the engine and the way the filter was installed, the advert says 9hp gains which is a very vague way to state the gains, percentage gains and the type of engine should have also been mentioned.
Important question is 9 bhp is what percentage of the total ?
chetanhanda is offline   Reply With Quote
Old 3rd October 2007, 08:55   #287
Default hi!
now a days engines have to follow so many constraints and the technology<i mean petrol>is not progressing that fast, so now we cant expect 50% rise in a single bolt on application.
now we all need to collect 2% from here 3% from there another 2% from some where.
the big bang days for little money -with reliability are over for sure.
so assuming that the original intake is tooooo restrictive& assuming that the replacement filter<of any brand> is not so restrictive then 5% gain is HUGE by todays standards .
Originally Posted by BUSA View Post
9 more hp for a 180bhp vehicle is just 5% increase, not a tall claim by any standards.
TURBOSAM is offline   Reply With Quote
Old 3rd October 2007, 20:32   #288
BUSA's Avatar
Turbosam - A performance filter with a well designed CAI can easily give 5% more power. So the gain aint huge in any way.
Old 20th October 2007, 01:36   #289
Default may be!
if the combo can give 5% more powerEASILY <with same or better quality filteration than stock 5 micron 100 filteratin > then great ,really great! but still 5% gain is really good thing to start with...
u can start searching for 5%each at 15 different places..
and u will end up with the best of the engines around..
all the best
Old 18th November 2007, 20:42   #290
BUSA's Avatar
Whats the point there? You dont put 15 CAIs in a car.
Old 21st November 2007, 11:03   #291
vibzez's Avatar
Somehow, diesels are easier to work on, simple pete bolton, and 15-20% increase.
vibzez is offline   Reply With Quote
Old 21st November 2007, 11:18   #292
Thanked: 1,642 Times
Agreed, 24 bhp and 75 nm after a 10-min job sounds rather easy to me. Just got mine done and no its not Pete's.
Steeroid is offline   Reply With Quote
Old 21st November 2007, 11:35   #293
1self's Avatar
Thanked: 270 Times
Busa, what Turbosam meant was that 5% each by doing other mods, like headers, underdrive pulleys, cams, upgraded ecu etc.
1self is offline   Reply With Quote
Old 27th November 2007, 08:49   #294
Default thanks!
thanks for understanding my point of view!!
even f1 designers look for 1%here another 2%there and sum up to 1100hp when rules and regulations allow them to...
even mobil 1 helps the same way ....cutting losses <read adding net usable power>
Old 27th November 2007, 08:52   #295
Default hi!
<no offence intended!!!>
this is a classic example of how one can mis understand someone in totality!!!ha ha ha
Old 7th December 2007, 16:19   #296
doomsday's Avatar
Post
It is not the fact that an engine is a diesel or a petrol that makes it easier to work on. The fact that the engine being worked on, is a FI unit, helps. With a turbo/SC setup it is much easier to boost the power output reliabily since the manufacturer plays it safe and uses low spec parts from its bin to keep overall costs low and ensure longer engine life. Also the boost and other variables are kept on the safer side.
For citation, take the Skoda vRS. It is 150 bhp from the factory, and it runs on petrol. A simple piggyback upgrade, which plays with the fuelling and timings sees the power climbing north of 180 horses. Any upgrade after this requires many more replacements, like intercoolers and even upgraded turbos in later stages.
Hence, the ease of performance upgrades is more in the favour of factory fitted TC/SC cars rather than naturally aspirated vehicles. Does not depend on the fuel an engine burns.
doomsday is offline   Reply With Quote
Old 8th December 2007, 08:11   #297
vibzez's Avatar
Makes sense. Thanks.
Old 14th December 2007, 02:04   #298
v1p3r's Avatar
Thanked: 27 Times
So you think a cat-con is not restrictive?
This is what a Swift's cat looks like. Look at it and tell me it's not really deducting from the engine's breathing ability.
Old 14th December 2007, 02:15   #299
Thanked: 17 Times
Dude! It looks like the latest range of speakers made by the Israeli company called Focal! What is it doing in a cat con?
Old 14th December 2007, 10:18   #300
vikram_d's Avatar
Thanked: 940 Times
Wonder what effect drilling a few holes in the catcon have
Dude wheres your car? The "invisible" car from Merc vinod332002 The International Automotive Scene 13 6th July 2012 17:18
Rtech dude......correct if i'm wrong. Shan2nu Shifting gears 16 20th May 2004 17:26
