| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #331 (permalink) |
| BHPian | Post deleted by the Team-BHP support : Do NOT SPAM the forum with useless one-liners that add no value to the thread. We advise you to read our rules before proceeding any further.
__________________ symbianoasis.com Last edited by GTO : 8th March 2009 at 16:25. |
| | #332 (permalink) |
| BHPian Join Date: Mar 2008 Location: Rome, Italy
| OK, my own 2 cents here... I drive (drove... she's been sitting in my garage for the best part of four years now...) a 1980 MGB GT, stock 1798cc engine, which is long bore, low compression, 94bhp SAE net which really means anything from 70+ to 80-bhp DIN. I will omit discussing ECU-controlled piston-operated robots, they are about as exciting as a corpse; sure, they may provide performance, but they don't have personality. My car? She's a lady... MOODY !!! So, here goes: 1) Stage 1: replace stock (paper element) air filter with hi-flow foam filter, up to twice as much air flow as standard element and when it's grimy you just wash it and oil it; hi-flow exhaust manifold; if possible, replace diaphragm-type silencer(s) with "double-S" type silencers (if at all possible, replace central element with "boom-box, not any noisier but engine growls rather than barks) Replace vacuum advance distributor with centrifugal type. OK, Now that we've improved air flow in & out, rejet carbs, then do a test run, you'll be surprised! 2) Stage 2: head off: skim and polish head, polish intake and exhaust ports, machine valve seats and fit the largest valves that'll fit; camshaft depends on destination of car (fast road / sprint / rally etc) fast road is best for ordinary traffic, others are too "uppity" and will be detrimental to overall enjoyment; balance (do NOT lighten!) flywheel... 3) Stage 3: burette combustion chambers and polish/skim in order to bring all chambers to same capacity in cu.mm.; weigh and balance all pistons, con rods and replace all crankshaft bearings with HD/performance type; replace oil pump with HD hi-flow pump (you don't want more pressure, you want more flow=>larger pump=>oil by the bucketloads!); air filter box should be at least 20 times cc capacity of a single cylinder; fine tune intake with "trumpets" (length varies with rpm, the higher the rpm, the longer the trumpets) from 1/2 to 1.5x throttle body diameter (i.e. on SU HS4, 1.5" throttle = 40mm, trumpets vary from 20mm to 60mm; I have 35mm); balance prop shaft on rwd cars; lube differential with thicker oil. DON'T FORGET TO UPGRADE SUSPENSION AND BRAKES !!! |
| | #333 (permalink) |
| BHPian Join Date: Jun 2005 Location: ERNAKULAM
| Please do not be misled by people who claim horsepower increase from changing severly worn out plugs to Iridium plugs by more than 1% of the total horsepower. Read the real story from the NGK website. NGK Spark Plugs USA
__________________ Bye and wear your seat belts. |
| | #335 (permalink) | |
| Senior - BHPian | Quote:
What the gurus here think about these advice especially 1, 2, 3 & 5 ? Are these really worth or simply placebos ? ![]()
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. Last edited by theMAG : 28th July 2009 at 14:43. Reason: Merged with similar existing thread | |
« Esteem 2002 - RPM Fluctuation (Blip) After Changing Gears
Retrofitment Of Electric ORVM's in WagonR »
| Thread Tools | |
Similar Threads | ||||
| "Good Day, I am interested in test driving..." "Sorry Sir, We dont have a car for TD" | Dippy | Indian Car Dealerships | 46 | 12th November 2009 18:50 |
| ANHC / Honda City Auto: Story of "Singh"'s boo"King" | singh_dfi | Test-Drives & Initial Ownership Reports | 46 | 31st July 2009 10:00 |
| Finally !! - Long awaited "BEFORE" & "AFTER" pics of my Avenger 200 !! | VSG12777 | Motorbikes | 23 | 16th June 2008 20:26 |
| Audi RS5 "M3 beater?" to be launched early next year "PICS" | highwayblaze | The International Automotive Scene | 9 | 18th May 2007 02:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
