Thread Tools
Old 6th April 2007, 09:44   #1 (permalink)
safari dude's Avatar
Default My Safari Suffer...ings!
Hi! Safari Dude here. Bought a safari in Oct 06, LX, and got it outfitted really well. Had been driving it ever since and was recently posted out from Mumbai to Kochi. Dream journey for the driver (self), and after despatching the household goods by truck the family and I ( family consists of wife, two kids aged 12 & 8 and a 2 yr old dog named pluto)
With the long drive in offing, got the safari serviced at 19,500 Kms 02 weeks before starting from Mumbai to Cochin. Started on 25th from Mumbai and reached Goa on the same day evening around 1930 hrs (NH 17 is not exactly a dream run, but the scenery is fantastic). While on the way somewhere after Ratnagiri and before Goa ( Rajapur) the "Check engine" light came on. Stopped the vehicle and let it cool down. Restarted again and the light stayed off for quite sometime but came on again after 30 min or so. Called the Tata helpline on my mobile and informed him about the problem again. He said that show the vehicle at Goa. Next day at Goa went to ND Naik and Sons and handed over the vehicle telling them about the problem. They checked the vehicle and gave it back after 21/2 hrs saying that the sensor was mal-functioning, nothing was wrong with the vehicle.Spent the day enjoying the sites and sounds of Goa and with a cool mind started off next day(27th Mar) for Cannanore (night halt). Well we were not destined to reach Cannanore that night as the vehicle started emitting copious white fumes at Suratkal near Mangalore and we had to stop call helpline again and inform them about the problem. They gave a Mangalore no. of Auto Matrix and the service Engineer said to check if the oil light was on? It wasn't so he said to drive on and try and reach the show room. So we trudged on at 40 Kmph or whatever the highway traffic allowed with everyone from the opposite direction pointing at the white fumes. Finally near the town the vehicle oil light glowed and we stopped again. Rang up automatrix and the service engineer said Put oil and drive on. We put 5 lit Engine oil and drove on to town. Stopped near the airport turn off to ask directions and the oil light came on again.Then I decided not todrive any more and asked the service engineer to come help and tow the car as I was scared that the Engine would seize now if the car had already digested 5lit oil in less than 10 min.So after a 30 min wait the tow veh - a tata mobile arrived and took us to the service station.By now I was really feeling tremendously let down by the break down. The service Engineer said he would take a day to let me know what the problem exactly was. I told him about the check engine light and showed him the Goa service slip.He got back to me the next day and informed me that the Turbo Charger oil seal and bearing had failed because of oil pump failure and the steering cross nut was very loose. Iwas lucky to have escaped incident free and arrived in Mangalore. The bill would be about 70-80K. Well, stayed overnight at Mangalore, and then took a train to Kochi, with dog squeezed in with the guard (that's what we wanted to avoid in the first place!). Waiting to receive the car and wonder if I would trust it again for a long drive! Would the vehicle still be road worthy? or should I put it under the hammer?Expert Comments welcome
safari dude is offline   Reply With Quote
Old 6th April 2007, 10:21   #2 (permalink)
Godfather's Avatar
This is definately a weird problem that you have faced..
I have a few questions,
1. What were the speeds you were doing on the highways??
2. Did you frequent any stops and before siwtching off the vehicle did you idle it for a couple of minutes here( Note..it has to be more than 5 Minutes as there would be lots of high speeds involved and the turbo would have been on continously)
3. Did you hit any pot holes in good speeds?
Godfather
__________________
I accidentally installed the deer whistles on my car backwards. Now everywhere I go, I'm chased by a herd of deer.
Godfather is offline   Reply With Quote
Old 6th April 2007, 11:02   #3 (permalink)
hari_rama's Avatar
Do you idle the car for sometime after every starts n before turn offs??
check this thread.....am not an expert,but the damage to turbo seal maybe due to it....
http://www.team-bhp.com/forum/techni...hut-off-2.html (Do all Turbos require idling before shut-off?)
hari_rama is offline   Reply With Quote
Old 6th April 2007, 11:17   #4 (permalink)
Sideways's Avatar
Goddy / Hari Rama, they've found fault with the oil pump. Probably wasnt supplying required oil pressure due to which turbo internals failed. So it's not that the turbo failed due to not idling the car sufficiently after high speed driving etc.
Safari dude, if i were you, i'd check compression. This would probably indicate if there was any internal damage caused due to starvation. Also check for any blow by vapour. Knowing Tata, they will attribute any future failure to this problem. If I were you i'd get rid of the vehicle and pick up another one.
__________________
Action on the MMST race track, Chennai - 4th & 5th October 08.
Sideways is offline   Reply With Quote
Old 6th April 2007, 11:30   #5 (permalink)
extreme_torque's Avatar
@Safari_dude... If it was oil sump failure, shouldn't it be covered under warranty?
extreme_torque is offline   Reply With Quote
Old 6th April 2007, 11:38   #6 (permalink)
Godfather's Avatar
I did think of this at first and after your comment i read the entire scene again..
1. the car had the check engine light on for sometime.. Then came on again after 30 min ( Prob -- Sensor Malfunction)
2. The car was checked in Goa.. There were no White Fumes before that IMHO this happened in GOA during checkup, something was missed out here / not put back properly ( Prob -- Oil Pump Failure)
I have my doubts here as the problems cropped from one to another.
If there was an Oil Pump failure and loose steering cross nut would the vehicle have made it from Mumbai to Mangalore.. distance of approx 700 Km??
Godfather
__________________
Old 6th April 2007, 11:50   #7 (permalink)
Jaggu's Avatar
get your vehicle checked thoroughly before you decide anything, and if you were actually relocating, this might be a good time to get a new car (whichever make/model) and since the car is just an year old try to get the best price possible at this time
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 6th April 2007, 11:55   #8 (permalink)
gd1418's Avatar
Infractions: 0/1 (4)
Hi S_dude,
Sorry to hear about your ordeal and loss of trust in TATA. I've been owning a '98 4x4 and have done several long distance including GGN-BOM-GGN run.
Never had any any problems and no breakdowns (if you like the flat at Ankleshwar can be termed as one). Why so - is it coz the TASC here in Delhi/GGN do a good job? No way.
I never and don't go to TASC at all. I trust my local garage who has been ahndling all my vehicles from day one. To hell with the warranties..
Safari is an excellant machine and flowers up on highways. No other truck comes closest to it interms of driver & co-passenger comfy, road-grip and prescence. Even the huge tankers give way...
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 6th April 2007, 13:12   #9 (permalink)
zucchero's Avatar
guys sorry for posting it but most probably getting my new dicor within FEW days.now after reading these problems in safaris i am nervous,i mean damn nervous.i want to back out but i am insanly in love with this vehicle but if i am not the lucky one then i would be dead guys bcoz its only me who wants the dicor the rest of my family members wants a trouble free(compared to safaris)car may be a honda city,lancer or hyundai.i am stuck guys.what should i do?
zucchero is offline   Reply With Quote
Old 6th April 2007, 13:56   #10 (permalink)
theMAG's Avatar
Go for the Safari. While Safari Dude has had some bad fortune, and Tata's are not necessarily known for their reliability, their quality is improving.
__________________
If you lose your temper, you’ve lost the argument
Old 6th April 2007, 14:48   #11 (permalink)
condor's Avatar
Safari Dude, like Hari asked, have you been following recommeneded start-up and shut-down procedures ?
Zucchero, I would agree with theMAG. I guess you would have read Steer's reports & reviews. Just remember to follow any instructions given in the owners manual and also common-sense stuff to take care of your dream ride... basically, do not neglect things like idling, warm-up, cool-down, proper fuel ..
__________________
Life is Analog. Digital is an approximation.
All kinds of animals come here ... and the occasional demon too !
Old 6th April 2007, 17:08   #12 (permalink)
esteem_lover's Avatar
This sucks big time. All preparations made to enjoy a wonderful ride & this had to happen. 6 months old car, who would expect that to act up like this ? I feel sorry for you safari dude. Isn't your car covered under warranty ? Why would you have to spend anything on it ?
__________________
R.I.P Islero
Old 6th April 2007, 18:47   #13 (permalink)
its reading about stuff like this about tata that shakes me up....
sorry s_dude to hear about your ordeal.
as a future safari buyer it completely rattles one's faith.
as i understand it s_dude did everything okay to prepare for a long drive.
had the vehicle chked and serviced, called the service helpline to chk with them when he started having trouble, took it to a TASS in Goa, where they give him a clean chit to drive on,again called the helpline, drove on, then had it towed, took it to mangalore where he was given a bullet to his head.
couldnt tata figure it out earlier?in goa?whats with the prospective damage amount of 80k?where is the warranty?
and what faith do people have in tata as a car company with senior members already telling him to sell the 6 month old truck?
my heart sank to my boots hearing that.
doctorkats is offline   Reply With Quote
Old 6th April 2007, 19:01   #14 (permalink)
Steeroid's Avatar
Very correct - if it was a malfunction shouldnt it be covered by warranty? ESPECIALLY since you had the vehicle checked up in Goa by people who said nothing was wrong.
But I'm a bit curious as to how you were able to make it from Goa to Mangalore if it was indeed an oil pump failure as claimed by them!
I doubt if you will be billed for the damage, but that does not take away the trauma of a well planned trip going totally awry. I can imagine how it feels to leave your dog in that miserable, dirty, dog-box in the guard's cabin.
PS: Just realized your Safari was bought 2nd hand http://www.team-bhp.com/forum/332085-post29.html (USED Safari(diesel)or honda city?) . Did you get the vehicle serviced after Oct 06 when you bought it?
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 6th April 2007, 19:57   #15 (permalink)
zucchero's Avatar
yes MAG and CONDOR bhai.i would be lot more carefull with safari bcoz i dont want to take any chances.as far as backing out i think its not possible and in case anything happens i know i got the entire team to help me out
Thread Tools
When Safari lovers TD a Scorpio mHawk! EDIT:Its a Safari tsk1979 Test-Drives & Initial Ownership Reports 278 27th July 2008 22:57
Do you suffer from Nomophobia? amit Shifting gears 28 9th April 2008 16:05
What to choose safari petrol or Safari diesel 2.2L 007 Bond SUVs, MUVs & 4x4s 22 31st August 2007 21:56
Does Palio suffer from cabin noise? amitsingh08 Hatchbacks 25 6th August 2007 17:21
Safari TCIC LX or Safari DICOR LX arindam SUVs, MUVs & 4x4s 19 10th January 2007 16:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
