| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) | |
| BHPian | Quote:
| | #17 (permalink) | |
| BHPian | Quote:
The only tell tale sign was with the cold start when I had to crank a little bit longer (say, like 1-1.5 secs earlier, compared to an instantaneous start with the new battery). | |
| | #18 (permalink) | ||
| Senior - BHPian | Quote:
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. | ||
| | #19 (permalink) |
| Senior - BHPian | The battery on my Maruti cars lasted lower. Perhaps the cheaper the car and the more green the buyer, the lower they cost. For me: Maruti 800: first car, bought in Sep 95, battery conked out in Mar 07 after 30K on odo. Zen: bought in Apr 99, battery conked out in Feb 02 after 31 K on the odo. Corsa 1.4: bought in Oct 03, battery replaced in Jan 07 as a precaution (`experts' indicated terminal disease and warned of passing away within the next 1-2 mths) Corolla AT: bought in Mar 07, no signs of conking out as of now. |
| | #20 (permalink) | |
| BHPian | Quote:
Wagon-R July2002 - still going strong VersaDX Dec2003 - still going strong Alto Lxi - Sep 2003 - still going strong I believe the MPFI car batteries last longer as they start easier.Also as a rule,new car batteries last longer as the wiring,alternator are all new.With time,the conductivity in wires drops,leading to alternator working harder.Also accessories' wired irresponsibly can also cause significant reduction in battery life.
__________________ Som Challenge The Impossible!!!!! | |
| | #21 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| @mithun: See i believe old or new, electrical should be pukka, coz of the simple reason that you can loose the car and is a danger to life due to fire, so first and foremost check electricals are fine then go for a battery check
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #23 (permalink) | |
__________________ The Road less travelled, is less travelled for a reason | |
| | #24 (permalink) |
| BHPian Join Date: Feb 2005 Location: Loveland, OH (cincinnati area), jabalpur, chennai
| Not much, because all I got was a piece of graph paper, and I don't have it with me anymore. They told me that AMP reading on the motor while on load was not looking healthy. probably some burnt coils. from my electrical knowledege, it could also be a failure in roating parts causing back emf and irregular AMP output. anyway,I changed the starter and all problems went away. (fixing it any other way would have costed much more )here is a link that discusses similar test results. Eastman Chemical Company Motor Analysis
__________________ ______________________________________ with great power, comes great responsibility. bigger the car, longer the cleaning time. |
| Thread Tools | |
Similar Threads | ||||
| urgent...battery needs replacement, what brand?? | clipto333 | Ask the Gurus | 50 | 14th August 2008 15:31 |
| TATA Motors Ace Truck-Signs of the future? | Steeroid | The Indian Car Scene!! | 71 | 17th October 2007 19:19 |
| Battery Replacement... | karthik247 | Technical Stuff | 72 | 26th June 2007 16:11 |
| Sania signs up for Getz | normally_crazy | Shifting gears | 13 | 27th September 2005 10:09 |
| DC signs for Red Bull.. | Hatari | Motor-Sports!! | 11 | 23rd December 2004 21:32 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
