Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 8th April 2007, 02:28   #1 (permalink)
Default I can go only 157.5 km ?? on CNG
Hi ,
I guess I will convert my zen on CNG but have small quarries, plz help me to solve those :
1) From lots of thread I cam to know max tank size for CNG is 14 kg, in that you can fill only 10.5 kg, that means if FE of my zen is 15km then after filling tank completely I can go only 157.5 km, is that true ??
2) If I am running car with A.C on, will get CNG smell in cabin ??
plz answer above queries
Thx in advance
JItendra
nicejits is offline   Reply With Quote
Old 8th April 2007, 14:06   #2 (permalink)
wolfinstein's Avatar
Suggest you go for a smaller tank of 12 Kg rather than 14 its too big and heavy for a zen.
On an average I can fill in 9.5-10 Kg during Winters,In summers around 8-9 Kgs.
My XETA gives me a Mileage of 17-18 without AC and around 11.8-12.5 on petrol, So I guess Your Zen will give more than its existing mileage on Petrol, Considering the Zen is 900 cc engine and Indica is 1405 cc engine.
CNG has slight ammonia smell, but you can hardly smell it since, it is lighter than air so it dissipates immediately incase of any leakage, compared with LPG which is heavier and sticks low incase of a leak. ( Auto-LPG also has a slight odour like normal LPG Cooking gas but much less)
You can never fill in a complete Tank of gas, Max I have got is 10.8 for a 12 Kg Cylinder.
My daily run is 38 Km and I hardly drive on Petrol. The fill on average lasts me 4-5 days
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 8th April 2007, 16:23   #3 (permalink)
nitrous's Avatar
Smell inside the cabin can only mean one thing - Leak!
From Wolfenstein's FE figures, i see that he's getting around a 40% increase in mileage when run on CNG.
So, with 10.8 kgs of fuel in a 12 kg tank, considering that ur FE is 20km per kg.
Ur range would be around 220 kms atleast.
__________________
Han:The Red Evo's yours
Sean:What do u mean?
H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai?
Old 8th April 2007, 17:13   #4 (permalink)
URJA's Avatar
The distinctive CNG smell comes only from the outside...if its in the cabin that mean you gotta leak.
__________________
2004 NHC MT
2009 Accord AT
URJA is offline   Reply With Quote
Old 8th April 2007, 17:55   #5 (permalink)
Default Smell in Cabin. of CNG Fitted Zen.
Pl . check using soap water all the joints ,(Ferules) metallic tube connecting the pressure regulator for leakage. on leakage tighten the joint slowly, ( Not over tighten it) , & re check with soap water again. till leakage stops.
The main reason for low FE seems to be only LEAKAGE.
Suneel Gore
novatekcorp is offline   Reply With Quote
Old 8th April 2007, 18:55   #6 (permalink)
220km is dissipointing for me, as travels mumbai to pune, mumbai-Baroda ( 450km - one way ) what shd i do ??? wil i get CNG filling centers, out side Mumbai??
Thread Tools
Swift Lxi (CNG Fitted) vs Santro GLS (CNG) coolaxe Hatchbacks 15 13th October 2009 17:43
CNG Oil Change - Regular or any CNG specials? panky12345 Technical Stuff 3 12th February 2009 01:01
Lancer now in CNG !! msdivy The Indian Car Scene 3 21st December 2006 10:46
V6 CNG jesal Shifting gears 6 25th May 2004 15:11
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
