Thread Tools
Old 8th April 2007, 22:25   #16 (permalink)
deep_bang's Avatar
Originally Posted by pogusingh View Post
More scary stuff, is there some problem with INDIGO guys? OR do I say either
1) Too much of bad roads in BGLR
2) Too much of bad quality control from TATAs
-POGU
Dark_lite and Werfish, what is the mileage on your cars? I am just trying to see if we can have some indication of when the belt *might* fail. Well.. there are hundreds of Indicas running without a problem. So, these may be (hopefully) isolated incidents.
deep_bang is offline   Reply With Quote
Old 8th April 2007, 23:27   #17 (permalink)
Mine is close to 13000,bought it last January.
werfish is offline   Reply With Quote
Old 9th April 2007, 09:45   #18 (permalink)
deep_bang's Avatar
Well, My brother's Indica too makes a little squeking noise in the morning. The service center guys have tried adjusting the tensioner but, the setting stays only for a couple of days. I Just am trying to understand if the problem is bad belts - cause, if that is so, i need to warn my bro to change it as soon as possible.
Old 9th April 2007, 09:53   #19 (permalink)
Su-47's Avatar
The effort is actually very very much, to the extent that the brakes are not really usable unless you drive very slowly.
Have tried this once when I switched off the ignition on a down-slope (I wasn't an enlightened tbhp member then). The car did stop but I had to practically stand on the brake. This was at about 50 Kph.
Both!!!
__________________
Never wrestle with a pig, for if you do, you will both get dirty, but the pig will enjoy it - Charlie Munger
Su-47 is offline   Reply With Quote
Old 9th April 2007, 10:49   #20 (permalink)
Talking of Indicas... At our office the metal covering on the drain was bent. When driven on one end, it used rise on the other end. Well, it used make that sound everytime you drove on it. But for two Indicas, it punctured the fuel tank and diesel was all over the floor. No other car ever had any problem. The fuel tank on Indica is a little broad under and does seem to be a little lower than other cars.
srishiva is offline   Reply With Quote
Old 9th April 2007, 22:12   #21 (permalink)
its done 27500km , bought it last april.
Dark_Light is offline   Reply With Quote
Old 10th April 2007, 00:37   #22 (permalink)
Team-BHP Moderator
Zappo's Avatar
This screeching noise of the belt is something that many cars throw up from time to time. However Indicas seem to be a little more prone to it. After I bought my car it started appearing within a couple of months, early in the morning during cold starts. That had me worried. I asked the mechs to check this out during the 1st service. They did but it returned soon enough. However after I again complained about it and they rectified it this sound has not come back till date.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 11th April 2007, 12:22   #23 (permalink)
Got the Vehicle repaired,they have changed the Power Steering pulley kit,Power steering oil was topped up.I was not charged anything.
Old 13th April 2007, 14:55   #24 (permalink)
It happened with me last summer, while driving on an isolated road in gurgaon at appx 70kmph, i spotted a bull in middle of road near about 100m, tried to slow down only to find pedal too hard.
but luckily distance was sufficient, road was free, i pushed pedal hard+immediately downshifted to 4th & took foot off the clutch+hand brakes & i stopped with in safe distance.
Started the engine again, tried acclerating, pedal would not come soft, so concluded it as booster failure & i was right, my booster was replaced under warranty, but it is very rare failure.
But you do have braking power left, press as hard as you can & use engine braking of diesel.
__________________
Arun
arunforu1 is offline   Reply With Quote
Thread Tools
damper pulley in the palio 1.9d sfilinto Technical Stuff 4 20th August 2008 17:38
Fall colors in NY/NH/VT/CT/NJ/Northeastern US abhijitaparadh Route / Travel Queries 9 14th July 2008 21:37
alternator belt damages timing belt??? jalsa777 Technical Stuff 20 3rd June 2008 20:53
Bernies Wheels fall off ! ajmat Motor-Sports!! 9 31st March 2005 22:40
Lightened flywheel& underdrive pulley on esteem anybody? Stage3Monster Modifications & Accessories 8 18th March 2005 19:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
