Old 11th November 2010, 01:35   #16
passionpurple's Avatar
Default one problem solved.new one started.
finally got my car back. the mech changed all spark plugs. now revs well till 7ooo rpm.
new problem. the feul injector error light is on. engine very sluggish in petrol mode.
please give me the differential diagnosis on this and probable solutions.
passionpurple is offline   Reply With Quote
Old 11th November 2010, 13:02   #17
bhp_maniac's Avatar
Thanked: 111 Times
Reset the ECU once. Then check if it comes back. If that doesn't help, get the injectors cleaned.
bhp_maniac is offline   Reply With Quote
Old 11th November 2010, 13:34   #18
CPH
Thanked: 34 Times
You can't reset the ECU yourself. The fault codes need to read and thern deleted. The warning doesn't come on for nothing.
CPH is offline   Reply With Quote
Palio 1.6 - LPG Conversion Warning RevvMusic Technical Stuff 12 19th September 2013 23:14
Palio GTX - Engine problem after rebore nim_peter Technical Stuff 11 8th May 2013 16:06
Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode shineshine Technical Stuff 9 10th May 2009 04:52
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 18:09
