Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 8th April 2007, 22:36   #1 (permalink)
HAFI's Avatar
Unhappy Problem With The Engine Rpm In Palio 1.6 After Lpg Conversion
hey,
i had recently installed an LPG kit for my FIAT Palio 1.6.It was realy a difficult job to get the right mixture(a part of the LPG kit which controls the gas flow into the air intake pipe)kit since the engine being so powerfull.
After the install there seems to be a problem with the rpm of the engine...when the RPM goes high(say above 3000) it comes down slowly...and if we are at higher speeds,the rpm doesnt go down as it usualy does...it goes down very slowly.But it behaves normaly when converted to petrol...i now have to keep on pressing the clutch until the RPM goes down...the engine continously keeps on roaring as rpm stays high for a long time...
I went and had a talk with the people who fitted in the LPG kit.The guy told me that the sensor(one which controls the air intake and rpm ) is damaged and have to be replaced.But when i went to the FIAT authorized service staion,the people over there told that there is no problem with the sensor(they did not even check it) and if it shows problem with LPG ,it will definilty show problem with petrol..
But the guy who fitted the LPG argues that it wound show any problem with petrol because when we give the acclereation the injector injects fuel and when not given it wount inject fuel and hence the RPM goes down eventually and in petrol we cannot notice this change even if the sensor is damaged(I also feel that he is right).
I happen to see one more trouble now...the the RPM doesnt go up when the A/C is on(both in petrol and LPG)..Normally the RPM should go up so that it can balance the load of the A/C..It doesnt do so..and the engine knocks when the A/C is on.....and now there is a starting trouble too(both in petrol and LPG)...i have to press the accelerator initialy while starting the engine as the initial RPM while starting the engine is too low and the engine goes off if accelerator not given..
Some say that LPG kit cannot be fitted to 1.6..and no one suggests LPG for a 1.6...
All the techies out here please help me as iam in a confusion what had gone wrong with my car...should i remove the LPG kit or is it the sensor which causes the problem.. i still feel that the sensor must have damaged during the LPG fitment as the air intake pipe had to be removed and the mixture had to be fitted and refitted again(had to change the mixture many times as it dint make up with the 100bhp engine and atlast had fitted the mixture for a lancer petrol engine) as there is no specific mixture for a 1.6...
Guys please do help me on this....And is it true that an LPG kit cannot be fitted into a 1.6(disaster for me if it is a yes)...has anyone over here fitted in an LPG for their 1.6..if yes please do share in your views in here as it would be a great help for me..
HAFI
__________________
2004 MODDED ZEN |--| FIAT PALIO 1.6 GTX|--| 2002 BOLERO |--| 2006 LANCER |--| 2001 OMNI |--| 97 M 800 |--| 2004 HONDA UNICORN
HAFI is offline   Reply With Quote
Old 9th April 2007, 11:58   #2 (permalink)
mail4ajo's Avatar
There is nothing like LPG cannot be fitted on 1.6L engine. People have even done on cars like Optra and NHC. I sense that the installer has fixed the wrong kit on your car possibly the one used on 1.2L.
Can you check the rating of the Vaporiser? I am not exactly sure of the rating, but it has be higher than the one used for less powered cars.
__________________
*06 Alto LXi* *97 Zen LX* *03 HH Ambition*
*RC Cars - HPI Baja 5B SS, Thunder Tiger SledgeHammer S50, ST-1 & Sparrowhawk XB*
mail4ajo is online now   Reply With Quote
Old 9th April 2007, 12:43   #3 (permalink)
Which brand you are using for 1.6 ?
swathyd is offline   Reply With Quote
Thread Tools
Know about LPG Conversion.... sonycs Technical Stuff 172 29th April 2009 10:47
LPG Conversion woes in WagonR aks_karthik Modifications & Accessories 7 20th June 2008 13:44
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 19:09
LPG conversion for a FORD 1.6 wannaplay Technical Stuff 4 2nd June 2006 05:34
Facing a problem in Palio 1.2 engine amitverma Technical Stuff 18 24th April 2006 10:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
