Old 12th April 2007, 18:54   #1
rohan_fonseca's Avatar
Default Dumb question about sensors....but i gotta know
Have k&n & free flow on a zen. What would be the effect of disconnecting the
i. Oxygen sensor in the exhaust manifold
ii. AIT sensor
iii. TB position sensor
iv. MAP sensor
rohan_fonseca is offline   Reply With Quote
Old 13th April 2007, 19:28   #2
In some cases, such as with the AIT and MAT (and sometimes o2) sensors, your car would probably just run in "limp" mode and you would get trouble codes and a check engine light. Performance would go down.
In others, such as the MAP, MAF, TPS, and most likely o2 sensors, your car wouldn't be driveable, it would spit and sputter, possibly smoke, and you would have a mess on your hands.
You need all of these sensors for your car to operate properly. Many piggybacks modify MAF, MAT, IAT, and MAP signals to create power or fuel economy gains, but it is absolutely necessary for the ECU to get a reading from each of these sensors.
Some companies also make o2 sensor simulators...in case you have a bad o2 sensor, or you have altered your car in a way (exhaust mods, etc.), so that you have terrible emissions. The o2 simulator will send an immitated signal to your ECU showing it that everything is OK with the exhaust, when in reality, it is not.
nextlevel350z is offline   Reply With Quote
Old 13th April 2007, 22:35   #3
Actually posted that question because i had a weird situation. The oxygen sensor wire to the exhaust was cut( probably the wire was hanging close to the fan due to my negligence). Probably was that way for months. There was no drop in fuel economy or mileage. Also no engine warning light. Was wondering why. Have also seen an OHC with disconnected sensors(i.e. O2 sensor and IAT sensor). It is a well tuned car with no ECU upgrade!!! Is that possible?
Old 14th April 2007, 09:01   #4
rdkarthik's Avatar
Thanked: 11 Times
O2-
It depends on what car you have. Euro 2 suzukis run perfectly fine without an 02 sensor, but the Euro3 version through an error. Most of the newer cars may have issues with drivability in closed-loop mode (everywhere but full throttle )
AIT/IAT - Almost all cars run fine without this. Checklight will turn on. You can be sure you are not getting the best fuel mixtures and ignition timing
ECT - Same as IAT, but usuakll causes high idle and switches on radiatior fan.
TB and MAP - You can still use the car with either of them working,at the cost of drivability. On most cars you will not have any significant drop in performance in full throttle conditions .
rdkarthik is offline   Reply With Quote
Old 14th April 2007, 09:02   #5
rdkarthik's Avatar
Thanked: 11 Times
I guess possible if disconnected, but not so if sensor is connected but screwed.
Old 16th April 2007, 15:41   #6
To satisfy my curiosity, disconnected the O2 & AIT sensors. Car ran ok but with a small drop in performance.....(as measured by my b-Dyno )
Old 19th April 2007, 03:38   #7
chetanhanda's Avatar
Thanked: 44 Times
hahah you are an interesting RnD type of the guy ..
now try this out for me.. remove the TP sensor and measure the performance ..
chetanhanda is offline   Reply With Quote
Immobilizer - A dumb question Simhi Technical Stuff 32 14th August 2017 14:45
A man's gotta do what a man's gotta do : Night drive to Chikmagalur libranof1987 Travelogues 37 30th June 2011 20:43
Matiz : A dumb question on "reserve fuel lamp" kshastry Technical Stuff 25 15th January 2008 13:33
Another dumb question from a noob!! archat68 In-Car Entertainment 3 3rd January 2007 06:27
A dumb question milindbajekal The International Automotive Scene 8 10th September 2004 14:08
