Old 15th April 2007, 15:22   #1
raajks's Avatar
Thanked: 118 Times
Lightbulb Driving style for DOHC and SOHC
Do we need a different driving for DOHC and SOHC?
For DOHC's, the engine comes to life at higher RPMs, so we would need to rev the higher than what we would normally do for a SOHC before shifting up.
SOHC, delivers an excellent low end torque and flattens out at higher RPMs.
Would love to hear your thoughts on this.
Here is a cool link on a video on &
raajks is offline   Reply With Quote
Old 15th April 2007, 15:26   #2
abhibh's Avatar
Thanked: 34 Times
This is news to me. I thought that major difference between DOHC and SOHC is the CamShaft.
Old 15th April 2007, 18:11   #3
v1p3r's Avatar
Thanked: 27 Times
Info is wrong. "Coming alive" at higher RPM depends on the characteristics of the camshaft(s) and the engine, be it SOHC or DOHC. Have seen SOHCs with no pull until 6000 rpm, then manic pant-wetting power till 14000 rpm. And DOHCs with immense low-end torque.
Old 15th April 2007, 21:03   #4
generally, DOHC's should be able to do everything that an SOHC does well, and better. Most engines, unless they come with variable valve timings, would be rated for one particular kind of use - cruising, dogfights, etc, so independent of their cylinder head and camshaft design, you will find differences between engines.
wizardofid is offline   Reply With Quote
Old 15th April 2007, 22:57   #5
I am not sure if that is neccessarily true. Theoretically, we could have a SOHC that could be be a dud at lower rpms and vice versa for the DOHC. As far as the driving style of the car goes, drive the car with its merits in mind. sohc, dohc and vtec or what not, in the end what matters is how the power comes through.
Sparkie is offline   Reply With Quote
Old 16th April 2007, 13:54   #6
raajks's Avatar
Thanked: 118 Times
v1p3r -- You are right.
What I meant was DOHC (CAM component) is heavier that SOHC
With a right timimg belt, SOHC can have a higher torque when compared to a DOHC as the amount of energy that is needed to time and lift two valves would be lesser that what would be required for the SOHC's
If you notice, most of the JAP's employ SOHC's
Whereas European and driver or race oriented car were DOHC.
The intention of the thread was to share a video on the internal workings of DOHC.
Thanks for the "light of knowledge" folks
Old 16th April 2007, 14:02   #7
theEnd's Avatar
If you compare a DOHC and a SOHC - everything else being the same - the DOHC would be superior because it offers more precise timing of both the inlet and the outlet cams. This is the major benefit. Sure, the DOHC will be slightly heavier and will require slightly more energy for the second camshaft, but this is usually negligible.
But every engine will have different characteristics, regardless of SOHC/DOHC.
theEnd is offline   Reply With Quote
Old 16th April 2007, 14:56   #8
sbasak's Avatar
One's driving style should not be changed whether it is DOHC or SOHC.
To drive any engine optimally, all you need to know is the power torqure characteristics (ie. at what RPM what torque is produced) - so that you can get max. fuel efficiency.
sbasak is offline   Reply With Quote
Old 16th April 2007, 15:41   #9
WhiteKnight's Avatar
Thanked: 76 Times
What are the "two valves" you are refering to? Would you please explain?
If I notice, there is a shift to DOHC by almost all manufacturers. I cannot see any Japanese maker still sticking with SOHC. Would you please back up with data?
I thought the primary driver for the shift to DOHC is better placement of valves that is possible with twin cams.
Afterall cams has got nothing to do with nationality
WhiteKnight is offline   Reply With Quote
Old 16th April 2007, 18:00   #10
v1p3r's Avatar
Thanked: 27 Times
The no of valves is totally independent of the no of camshafts. And you'd be hard pressed to find a single Jap manufacturer still selling an SOHC internationally.
Old 16th April 2007, 18:10   #11
raajks's Avatar
Thanked: 118 Times
Honda ZX -- SOHC
Mitsubishi Lancer Cedia -- SOHC
Old 16th April 2007, 18:23   #12
v1p3r's Avatar
Thanked: 27 Times
So is the Ford Ikon and Fusion, and I think Fiesta too. And how about the Palio 1.2? And the Logan 1.4 and 1.6? And while we're at it, I'm not sure about the Aveos...
Old 16th April 2007, 18:58   #13
sbasak's Avatar
Honda is selling Jazz with SOHC (source Honda (UK))
Old 16th April 2007, 21:26   #14
Shan2nu's Avatar
Thanked: 89 Times
More than the number of camshafts, it's the engine's state of tune and design.....that decides how and where it gets it's power.
Honda's 3ltr V6 (244bhp) used in the Accord Coupe and the 3.5 ltr V6 (297bhp) used in the Acura RL are both SOHCs, but do you realise this when you drive them?
Forget that, i've driven highly tuned OHC Vtecs that have very little to offer at low rpm but are unbelievably quick once you cross 5000 revvs. Compare that to my stock Vtec that has very good low end grunt but just cannot match the tuned ones, up the revv band.
Shan2nu
Old 16th April 2007, 22:15   #15
chetanhanda's Avatar
Thanked: 44 Times
basically you have got everything completely wrong.
v1p3r What I meant was DOHC (CAM component) is heavier that SOHC,
whats this ?
Why would you think like this ? so what if its heavier ? just becoz (even if it was) it is heavy doesnt mean SOHC is better than DOHC
no way .. how can you say that SOHC has better torque than DOHC ?? becoz SOHC weighs less..
and what do you mean by timing belt... since when did the "right timing belts" decide torque curves..
hey wait.. you are going totally off now by saying Jap cars are SOHC and not driver or race oriented...
chetanhanda is offline   Reply With Quote
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
Honda CB 750Four SOHC Xantos Superbikes & Imports 16 21st August 2015 12:59
Converting Esteem SOHC to DOHC MustangMan Modifications & Accessories 9 7th July 2014 17:54
Which engine is better? SOHC vs DOHC abhibh Technical Stuff 26 9th October 2010 02:45
Top stable speed on Accent GLS SOHC! rchandan The Indian Car Scene 19 6th February 2008 15:59
