Thread Tools
Old 17th April 2007, 13:30   #1 (permalink)
Fiero's Avatar
Exclamation IKON 1.6 : Oscillating RPM needle
Car : Ford Ikon 1.6 Sxi(nxt) 2003 , done 25000Kms
Noticed this problem my ikon .... when in 1st gear , when i start to move forward (say slowly in bumper to bumper traffic) with the clutch not fully released (as speed doesn't permit) ... the RPM needle oscillates slighty.
It happens at low revvs , say, between 900-1000 or 1000-1100 ... not noticable at higher revvs.
While this oscillation happens , you can feel it in the car ... moves forward with periodic resistance from the engine . Minute , but noticable.
History : Car was serviced about 10 days ago ... Injector cleaning was due at service ... did not get it done as i did not have the money that day ... Is this the problem ???
Also noticed that the engine , is not as smooth as it used to be if i let it roll in gear with the rpm falling below 1500 ... Not a major hassle , just comparing it to what it used to be like.
Also please tell me if there is a good workshop in south delhi where i can get Wheel alignment done + maybe the injector cleaning ... future spark plug replacements etc. or should i stick with Ford.
harpreet Ford , where i got the car serviced , did not have the required 'weights' to do the alignment job and the alignment is off so i need to get that done ASAP.
Thanks !!
__________________
When angry , count to four . When very angry , swear !
Fiero is offline   Reply With Quote
Old 17th April 2007, 14:35   #2 (permalink)
Pankaj401's Avatar
Could it be that your clutch is due for a replacement?
Pankaj401 is offline   Reply With Quote
Old 17th April 2007, 14:39   #3 (permalink)
suman's Avatar
Wheel alignment & balancing - Woodland Meadows in Green Park, Uphaar cinema market, opposite the Honda showroom.
Don't know about the rest of the stuff, better to stick to Harpreet Ford I think.
__________________
Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4
suman is online now   Reply With Quote
Old 17th April 2007, 16:30   #4 (permalink)
Fiero's Avatar
Guys at harpreet ford didn't mention anything about the clutch ... I'll have it specifically checked again.
__________________
Old 17th April 2007, 16:32   #5 (permalink)
Fiero's Avatar
K ... had heard about a workshop in Green Park .... may be this is the one ... pretty close to my place ... Thanks suman.
__________________
Old 17th April 2007, 16:32   #6 (permalink)
suman's Avatar
I don't think there could be any possibility of a clutch packing up at 25k but no harm in getting it checked out when you are there next........
(By the way, Woodlands Meadows is a tyre dealer not a regular workshop)
__________________
Old 17th April 2007, 16:55   #7 (permalink)
n_aditya's Avatar
For injector cleaning, use Sonax Injector cleaner, or Iftex System G which is available at most Bharat Petroleum outlets.
I use Iftex System G in my esteem and the power delivery is smooth and without any trace of knocking.
Use half a bottle of Sonax with a full tank of gas (once every 5000 kms only) while System G can be used regularly @ 1ml per liter of petrol.
Old 18th April 2007, 00:12   #8 (permalink)
1100D's Avatar
Hey Buddy, just try disconnecting the battery positive terminal and keep disconnected for 10-15 mins. Then connect back on and drive.
I may sound pretty funny on this, but I think this will work. If it does, I can tell you why you noticed this after your service.
__________________
________________________
Every Ferrari is always a Fiat
1100D is offline   Reply With Quote
Old 18th April 2007, 14:31   #9 (permalink)
benbsb29's Avatar
@1100D : Is it something to do with the battery?
I notice on my Pulsar that when the battery is weak, the RPM meter keeps fluctuating when i use indicators or the horn. I may be wrong here, or even sound stupid.
__________________
"Wise are they who invested in a diesel powered automobile" - Benny
benbsb29 is online now   Reply With Quote
Old 18th April 2007, 18:08   #10 (permalink)
Absar's Avatar
Bingo! This basically resets the ECU. The ECU should have data in it of a heavy foot driver which automatically refers to the Ford people while the car was with them. I do this ECU Reset every time I recieve the car from Ford..
-Absar
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Old 18th April 2007, 20:53   #11 (permalink)
Fiero's Avatar
ok . will try ... thanks guys !!
__________________
Old 18th April 2007, 21:13   #12 (permalink)
1100D's Avatar
Its actually because of the 3M throttle body cleaner they (Ford guys) use. Each time you give them the car for service, they spray this thing and this actually alters the engine parameter readings and the engine sort of hunts.
Anyway I think my foot's heavier than the feet of the Ford mechanics!
However Fiero try it out and let me know.
__________________
Thread Tools
Rpm does'nt go above 9k speed140 Motorbikes 25 18th October 2007 20:39
Ford Ikon mod - fiesta head on ikon block? madhunm Modifications & Accessories 2 2nd July 2007 09:24
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Fuel guage needle going up and down manikjeet Technical Stuff 8 14th March 2007 15:37
my speedo ended !!!- zen needle crosses last point on speedo speed0mania Street Experiences 81 11th August 2006 12:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
