Thread Tools
Old 18th April 2007, 15:28   #1 (permalink)
vebmetal's Avatar
Default Noise in the Clutch?
For some time now I get this stange noise in my Hyundai Accent where the engine or something seems to be going choon-choon-choon-choon. I only notice the sound when it's in neutral, but it's not a very loud noise so maybe it's there all the time it's on. When I press the clutch even slightly, the noise goes away.
I have checked the fluids - they are all fine.
What could it be?
vebmetal is offline   Reply With Quote
Old 18th April 2007, 17:17   #2 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Diagnose Replace Clutch
Check your fork/pivot ball contact point.
This will be fixed by the service center. Is your car under warranty? How many kms?
__________________
Reclaiming.....!
Old 19th April 2007, 22:11   #3 (permalink)
SLK
SLK's Avatar
How "slightly" are we talking about here?
If its not like just touching the pedal.. it could be ... something in the gearbox.... checked the gear oil?
Disclaimer: just an intelligent guess....
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Old 23rd April 2007, 15:50   #4 (permalink)
vebmetal's Avatar
slightly meaning I depress it say half a centimeter (to maximum a centimeter). The fluids are all good.
Old 13th May 2007, 09:58   #5 (permalink)
SLK
SLK's Avatar
normally the clutch doesn't get disengaged just by pressing 1cm.... so it should be the clutch of the gearbox....
at 1 cm depressing the pedal it only should be Clutch Release Bearing (CRB).... but normally it doesn't do the choon..choon.... sound,.... its more like... sshhhhhhhhhhhhhhhhhhh....
__________________
Č╠╣€€Я$
$£Қ
Thread Tools
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
Baleno Clutch kiranpashtakar Technical Stuff 17 16th January 2007 12:15
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
Clutch Shan2nu Technical Stuff 0 18th March 2004 21:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
