Thread Tools
Old 19th April 2007, 19:17   #16 (permalink)
16v100bhp's Avatar
Originally Posted by SLK View Post
If differential was the answer.. the wheel in air is the only one that is supposed to move...
I say its just the momentum of the car... they pick up speed... and while doing the stunt don't accelerate at all... just let it roll.
Otherwise if the wheels in air are completely stopped... they might have some kind of a single sided brake!
If you jack up one side and slowly release the power then the wheels in the air will be the ones which are moving, no matter how much you accelerate after that...
As you said the initial momentum should be what keeps the car running here...
Not sure of any special setup though....
__________________
-Ahmed
There's only two things I do really well... and driving's the other one...
16v100bhp is offline   Reply With Quote
Old 19th April 2007, 20:16   #17 (permalink)
Probably its a car thats specially kitted out for only rotating the left wheel! On a more serious note, when he is on 2 wheels, even very light brake inputs(which the driver might use to control the car in that situation) would be enough to stop the wheels in the air because they would not have much inertia as the load of the vehicle is not on them.
Did you see such a video on the net somewhere? In which case, could you provide a link? Cheers.
Sparkie is offline   Reply With Quote
Old 19th April 2007, 20:47   #18 (permalink)
sbasak's Avatar
wrong, the torsen doesnt work when one of the wheels is in the air.
The work around is explained here - see the "Hummer" part on right hand side towards the bottom of the page.
Howstuffworks "How Differentials Work"
__________________
Life is a math which you need to solve without knowing the answer!
sbasak is offline   Reply With Quote
Old 20th April 2007, 00:32   #19 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Worrisomebear,
It would help if you posted the video you were talking about...
Originally Posted by nitrous View Post
Differential lock is one probable reason.
Nitrous, i think if the diff lock is engaged BOTH wheels will ALWAYS rotate at the same speed, regardless...
Originally Posted by headers View Post
camera trick is the answer.
I will agree with this...it might have also been a bad quality video at night and its hard to see.
Also, if the front wheel is not driven, it will freewheel itself to a stop and this will most probably be the only wheel that is not rotating.
eg. @85seconds in this video
cya
R
Old 20th April 2007, 09:11   #20 (permalink)
vabs78's Avatar
@worrisomebear : which car was that?
I think AWD systems can cause this. they supply power to the wheel that has traction.
__________________
If everything seems under control, you are not going fast enough!
vabs78 is offline   Reply With Quote
Old 20th April 2007, 10:42   #21 (permalink)
This is the closest explanation and quite apt too. But any techies to explain if the wheel without traction loses power completely?
__________________
...looking forward to sit a few feet above mean road level and away from potholes...
gbpscars is offline   Reply With Quote
Old 20th April 2007, 13:04   #22 (permalink)
Team-BHP Moderator
Technocrat's Avatar
I did a serach on You tube for such videos & here the list
YouTube - Broadcast Yourself.
Check out this one 16 cars on two wheels
YouTube - Most Cars On Two Wheels
Not much is vible of the tire in sky but at exactly 3.05 secs you can see the stopped wheel of a white car(a renault I think)
I dont think there is any camera trick since its a Guiness record attempt
The wheel I belive are moving in this vdo
YouTube - Russ Swift Performing Two Wheels Stunt
__________________
180, 225, 150, ??? -> 159?
Old 21st April 2007, 02:01   #23 (permalink)
v1p3r's Avatar
I said that! LSD! Any wheel with traction gets all the torque. Wheel in air = zero traction = zero torque supplied!
__________________
Singh is king?! He's a bloody baadshah!
Old 21st April 2007, 10:19   #24 (permalink)
Jomz's Avatar
In [ applications, a limited slip differential (LSD) is a modified or derived type of gear arrangement that allows for some difference in rotational ] of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an , such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity
this is from Wikipedia... It seems that LSD does not allow to increse the speed difference beyond a set limit.. so it means.. Both wheels will spin.... right???
IMHO it is possible if the driveshaft to one wheel was disengaged and the differential locked... Torque steer balanced by Steering inputs..
Or driving after having LSD-Lysergic acid diethylamide - One psychedelic drug..
Jomz is offline   Reply With Quote
Thread Tools
The Air Car - Cars Running On Compressed air ? santhoshx The International Automotive Scene 27 24th July 2008 11:40
Dont know what to say humyum Shifting gears 25 3rd November 2007 18:46
Logitech's X Air Mouse Works on the Desk and in the Air !!! cypher Gadgets, Computers & Software 4 10th September 2007 07:47
Air filter and Air intake sunilvarma Technical Stuff 5 13th July 2007 22:20
why dont we have this ? normally_crazy Shifting gears 4 23rd October 2004 21:30
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
