Old 1st February 2010, 16:53   #16
gpa
gpa's Avatar
Thanked: 282 Times
This can be attrbuted to a case of no adequate belt tension. Check and tighten the belt. See if the problem persists and then change the belt.
Old 24th March 2011, 11:59   #17
Thanked: 127 Times
Default Re: Baleno - Power Steering heavy when AC is on.
Has anyone tried to change the PS in the Baleno to a manual one for power gains? How difficult is it to do this? Hopefully this would improve the steering feedback too.
heavy_foot is offline   Reply With Quote
Old 24th March 2011, 17:44   #18
dhanushs's Avatar
Thanked: 4,504 Times
There would not be any noticeable power gain by just converting to a manual.
Regarding steering feedback, yes, it will be improved, along with your biceps ,aided by loads of understeer at high speeds.
Old 24th March 2011, 17:59   #19
Thanked: 127 Times
The way i look at it, it would reduce some weight and since its a HPS, it would slightly improve performance. I used to have fun in my manual steering Zen, but the Baleno feels disconnected when compared to the experience i used to have in my Zen.
So is it doable? if so how?
P.S I already have decent rubber.
Heavy steering vibration on idle sweet_poison Technical Stuff 18 6th August 2015 14:15
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
