Thread Tools
Old 20th April 2007, 10:43   #1 (permalink)
Unhappy Less Low End Power in Ford Ikon 1.3
I have a Ford Ikon 1.3 CLXi thats done around 24000km. The problem I am facing is that with the A/C on there is very low pick up in the lower revs (till around 2700 RPM). Once this RPM is crossed, the acceleration is fine. Also, without the A/C also there is no problem with the pick up.
Any ideas on how to resolve this issue?
maverick is offline   Reply With Quote
Old 20th April 2007, 12:56   #2 (permalink)
benbsb29's Avatar
This is indeed true with all the 1.3s. What i do in these cases, is using the gears to extract max power from them, rather than being in one gear and accelerating through it. I am sure the performance mod gurus would be in a postion to suggest something here, although i have learnt to adapt to this in my car.
__________________
"Wise are they who invested in a diesel powered automobile" - Benny
Old 22nd April 2007, 13:49   #3 (permalink)
Astleviz's Avatar
I own an ikon flair and suffered from the same problem- Lousy pickup at low RPMs, esp. with the AC on. My suggestion to you would be to do what I have done (it won't turn your car into a rocket but will drastically improve your driving experience).
1. Get a free flow exhaust with header. I got mine from Automech but he will only give you a generic FFE (even that will do wonders), if you'd rather prefer a custom job , get in touch with Viper who will be able to help you out. My experience tells me that this will be the best mod you can do short of a porting-polishing job to get a reasonable increase. Just remember, where ever you get your FFE, tell them to give you a soft mellow sound, The deep roar sounds good initially but it can be a pain later, especially on long drives. This will cost you between 9,000-15,000 Rs, depending on where you get it from.
2. Strap on a conical air filter. I have a K&N with a custom intake pipe which I sourced from Viper, but I believe there are several other good filters out there. The filter itself doesn't give you a HP gain, but I guess it helps your engine breathe better and is a basic requirement if you intend to go in for future mods. I paid 6000 for the filter and intake pipe.
3. If this ain't enough (and if you have money to spare), try out the Tri-phase. I got mine from Viper. It makes a reasonable difference in initial pickup of the car especially with the AC on. I am able to get the car to move smoothly from much lower RPMs and it also seems to iron out a flat spot between 1500-2200 RPM.
Another Team bhpian Angad777 has done similar mods to his ikon flair and you could also get in touch with him to know his experience.
And finally, look up the thread on Acetone. I tried adding Acetone twice and "felt" that the car was less jerky at low RPMs and smoother overall. However I don't do that as a usual practice, I am quite satisfied with what I have now.
But if there was just one thing that you could do to, get a custom FFE and tell your guy to design it for bottom end gains (since that's where the ikon flair lacks most).
Cheers!
Astleviz is offline   Reply With Quote
Thread Tools
Increase Low end torque in Swift Petrol pshyamsundar Modifications & Accessories 5 4th April 2007 12:30
Mod for low end torque in Swift talk2anand Technical Stuff 34 31st October 2006 09:20
Loss in power in low RPM Sri_009 Technical Stuff 2 25th May 2006 23:24
JD Power : Low rating for Baleno venkatrx The Indian Car Scene!! 46 18th May 2006 08:04
giving the Swift some low end torque and fatter wheels theEnd Modifications & Accessories 14 21st November 2005 18:07
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
