Thread Tools
Old 20th April 2007, 20:23   #1 (permalink)
Default Electronic brakes. Possible ?
I was wondering with so many advances in automotive technology, why is there no talk about Electronic brakes ? By electronic i mean brakes using electrical motors and wires instead of the conventional mechanical system consisting of rubber hoses and plastic tubes etc.
The clear advantages of this system that i can think right now:
1. It will obviously save a lot of assembly and use of plastic.
2. Instantaneous signal to the wheels.
Maybe some other advantages, which i can't think of right now.
But the question is, if we can have Electronic power steering (which again uses motors and wires instead of the conventional hydraulic system), what is stoppig the automotive world from not using Electronic brakes ?
__________________
What goes around comes all the way back around
DCEite is offline   Reply With Quote
Old 20th April 2007, 20:30   #2 (permalink)
sbasak's Avatar
There are already electronic braking - ABS, EBD etc. are all some kind of electronic braking.
However, in many countries there is a legal requirement that steering, braking etc. can't be entirely by wire.
__________________
Life is a math which you need to solve without knowing the answer!
sbasak is online now   Reply With Quote
Old 20th April 2007, 20:37   #3 (permalink)
drifter's Avatar
What about electronic failures....
I don't mind electronics as a passive system (ABS, EBD). But I don't want to trust something as vital as brakes to chips and wires.
I think I'd feel much safer with a mechanical linkage.
Also in case of a failure of EPS, you can still steer.
In case of Electronic Brake failure, the wall, or a vehicle ahead stops you.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 20th April 2007, 20:55   #4 (permalink)
See here the Seimens Electronic Wedge Brake
Siemens VDO’s Electronic Wedge Brake reduces braking distances by up to an average of 15 percent
Siemens VDO has tested a revolutionary braking technology under extreme conditions close to the Arctic Circle. The results show that with the Electronic Wedge Brake (EWB), braking distances on icy roads can be reduced by up to an average of 15 percent. The brake innovation will be ready to go into series production in 2010.
Siemens VDO - Braking Technology
giri is offline   Reply With Quote
Old 20th April 2007, 21:04   #5 (permalink)
sreedotk's Avatar
One issue might be heat . Heat and electronics dont go hand in Hand. Another thing to consider is that Using an Elecrical/Electronic device for braking is really not that useful as by braking we are losing the momentum gained by the motion of the car and in principle we are wasting the energy . Thus the best use of electronics in Braking would be to gain the lost energy back. That is what the new generation cars (read as Hybrid) like prius does . It uses the energy dissapated by the braking forces to regenerate the batteries . The new versions of BMW's are also going to have some thing similar to recharge the electrical system. This enables the BMW to have an alternator system on Demand so the engine is not taxed having to run the alternator at all times.
ON a different note
If your idea of an elecrical brake was some thing like using the electrical energy to stop the car then it was utilised in a Speed record attempt to stop the car. The brake principle they used was an electromagnet which was designed to slowly retard the speed of the Car using alternate elctromagnetic pulses. It was in principle the other way of the Maglev (Bullet trains of Japan) .
I guess i might have veered off topic so i am going to stop. If you need more gyan on the maglev i think wikipedia has some good reading material
sreedotk is online now   Reply With Quote
Old 20th April 2007, 21:15   #6 (permalink)
iraghava's Avatar
Actually Mercedes did introduce Drive-by-wire Electronic braking on the current E-class & last-gen S-Class but after repeated problems they were withdrawn & the cars reverted to/scheduled to revert to Hydraulic systems. Some of the problems were:
1. No linearity in braking, the pedal is like a switch either on or off, no middle position. This make smooth braking quite tricky & irritating.
2. There were reliability issues also & even though Mercedes had built in a backup Hydraulic system the customers were not happy.
The argument for using Drive-by-Wire in cars (ala Airplanes) has been going on for a while but certain rules in Europe make it hard. They have to ensure very high levels of reliability which with the current level of Electronics is proving hard. But rest assured some time in the near future you'll cars with systems like Steering & Brakes etc. being driven electronically.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 20th April 2007, 21:24   #7 (permalink)
Fuelled's Avatar
Wasnt there some brake failiure in the SBC equipped mercs and that was just when an electronic module was used to apply the final brake pressure.
Cant even imagine how reliable electronic brakes will be(as of now).
Anyways Peugot was testing these items DCEITE mentioned some time back, But faced problems with ABS systems as the motors used to apply pad pressure weren't quick enough to respond to ABS's needs
PS: ur quick raghav
__________________
You're not drunk if you can lie on the floor without hanging on.
Fuelled is offline   Reply With Quote
Old 21st April 2007, 01:22   #8 (permalink)
vivekiny2k's Avatar
Location: Loveland, OH (cincinnati area), jabalpur, chennai
electronics can assist braking. but electricals can actually brake the vehicle (e.g. prius, returning the wasted energy to the battery).
another example is locomotives. they use regenerative braking. although they don't always return the energy to the system, rather waste as heat.
(they have dedicated cooling systems for that)
The reason they don't do mechanical braking is that at such high speeds and loads, mechanical brakes will simply break and fail. secondary and tertiary brakes are mechanical i guess.
__________________
______________________________________
with great power, comes great responsibility.
bigger the car, longer the cleaning time.
vivekiny2k is online now   Reply With Quote
Old 21st April 2007, 14:24   #9 (permalink)
elf
elf's Avatar
I think what dceite was trying to get across was Brake-by-Wire, not regenerative braking, like in the locomotives or the electric / hybrid vehicles.
Looks like they're still perfecting the technology. And if Mercedes Benz does a recall, you know there's some way to go yet before we see it in our Marutis.
elf is offline   Reply With Quote
Old 21st April 2007, 14:36   #10 (permalink)
^^ Yup Elf is right. I was talking about Brake-by-wire.
__________________
Old 21st April 2007, 15:43   #11 (permalink)
Team-BHP Moderator
tsk1979's Avatar
the problem with by-wire systems is that when they fail its all fail. Zero or 1
When your hydraulic brakes fail(eg fluid leak or vacuum pump failure) you will see that the brakes get very hard. Sit on the pedal and chances are you will stop without a major mishap or something.
In electronics when such a by-wire system fails, its all zero.
Thats why Boeing etc., which have by wire systems have multiple fall back circuits, one fails, second one takes over.
Now a 737 is a multi million dollar machine, and therefore the tolerances etc., they work with are affordable, to make your M800 that reliable, your braking system alone will cost more than a few lakhs.
So mercedes etc., will be the first ones to see such systems, and lesser mortals will have to be content with topping up the brake fluid.
Other factor is, if its not broken, don't fix it.
If with ABS and EBD you can get good braking without unnecessary complications, why do it?
__________________
Old 21st April 2007, 16:52   #12 (permalink)
wolfinstein's Avatar
Is'nt Drive By Wire- encompassing all features like Brake,Accelration,Gear Shifts and all, Something like a super advanced cruise control..!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 21st April 2007, 17:34   #13 (permalink)
iraghava's Avatar
No, Drive-By-Wire is the name for the electronic control of any of those functions. This all encompassing concept was a Mercedes concept in their Vision 500 car which even has a joystick instead of a steering. They wanted to integrate the brakes, steering, throttle etc. on Drive-By-Wire.
Here are some pictures of that concept which was shown around '98 and was a sneak peek at the then about to be launched S-class (W220).
__________________
Old 21st April 2007, 18:35   #14 (permalink)
elf
elf's Avatar
I don't see why the Brake-by-Wire technology, even with a secondary backup system should cost lakhs. I may be wrong, but it could simply be another wiring harness with duplicated sensors & switches.
Also, it doesn't have to be all or nothing. Not switches. Think potentiometers. And a servo could take care of pedal feedback, with the ABS system coming into play whenever the brakes are stomped on hard.
Methinks it's currently a more political issue than an execution & reliability issue, especially in Europe.
Thread Tools
Best place to buy electronic stuff? vidurm Gadgets, Computers & Software 15 19th November 2007 10:14
electronic emotions chanapli Modifications & Accessories 7 6th March 2007 09:46
Electronic wedge brakes[Lighter, better, shorter stopping distance & in cars near U] 1Day The International Automotive Scene 3 11th November 2006 22:05
And so it happens...First electronic glitch in the C220 GTO Technical Stuff 30 4th April 2006 22:16
Information about Electronic components Suryam Technical Stuff 11 27th September 2005 12:00
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
