Old 21st April 2007, 22:36   #1
karthik247's Avatar
Thanked: 16 Times
Default Swift clutch replacement - Suggestions needed ASAP!
Hey guys,
Swift's clutch got busted at 4977kms (Before 2nd service). It had a few probs earlier but it completely let go today. So now i need to get a new clutch, but i don't want the OE Swift one. I'm looking for an aftermarket one. Can someone suggest or help me get one, or recommend a brand and lemme know where i can get it.
I need it ASAP! Please, very urgent
karthik247 is offline   Reply With Quote
Old 21st April 2007, 23:19   #2
nitrous's Avatar
Thanked: 285 Times
Get the street-specific clutch in Exedy or SPEC. It will last longer than OE and wont be hard.
The Race specific clutch will last way longer but will be uncomfortably hard for road use.
Old 22nd April 2007, 02:19   #3
abhibh's Avatar
Thanked: 34 Times
how old is your car karthik ? Lately i have heard from many swift owners about the clutch problems of swift. Have you told about it to service center ?
Old 22nd April 2007, 02:22   #4
Mpower's Avatar
Thanked: 1,687 Times
check what the rally guys are using in their esteems. check if a baleno's clutch will fit?
What did you do to cause the clutch to burnout and why isint it covered under warranty.
Old 22nd April 2007, 03:00   #5
danlalan's Avatar
Thanked: 135 Times
Same problem happened to a friends swift..has to get it replace from the company in under 5000kms...got it replace for 6000rupees...Driver riding the clutch was the outcome of the wear...
danlalan is offline   Reply With Quote
Old 22nd April 2007, 03:06   #6
hey the swift clutch problem is common,changed 2 clutches for a friends swift in 20,000 kms,baleno clutch also doesn't make any difference,you need an after market clutch according to everyone's own driving needs and style they can choose one,im planning on getting one from clutchmaster's only waiting to find out if they even supply a lightened and pre-balnced fly-wheelfor the same...cheers...happy revvin...!!
dragger is offline   Reply With Quote
Old 22nd April 2007, 03:46   #7
v1p3r's Avatar
Thanked: 27 Times
WARRANTY! Clutch wear under 5000 km?! Not unless you smoke rubber for a living.
Old 22nd April 2007, 07:59   #8
navdeep's Avatar
and how much maruti guys are charging for a new one.
navdeep is offline   Reply With Quote
Old 22nd April 2007, 09:03   #9
karthik247's Avatar
Thanked: 16 Times
My friends Swift's clutch also got busted, that did 6k+ kms. So both our cars were towed away. He is again gettin the OE one while i'm looking at an aftermarket one.
How much does the Clutch Master's one cost?? Can u guys provide the price as well..
I need to get the clutch atleast by Tue/Wed so that i can get the car out this week itself. Otherwise i'll have to put in the OE one
Old 22nd April 2007, 09:04   #10
karthik247's Avatar
Thanked: 16 Times
Clutch is never covered under warranty for any car as far as i know..
Old 22nd April 2007, 11:23   #11
Surprise's Avatar
Thanked: 272 Times
Mine has crossed 25,000 kms and still everything is fine. I know dozen of swifts crossed 10 k mark in my office without any such problems. Really surprising to hear cluth getting busted at such lower kms.
Surprise is online now   Reply With Quote
Old 22nd April 2007, 11:41   #12
nikkibike's Avatar
ugh!! How did you burn it so quickly dude?!!
Talk to Peter of "petes" !! He may be able to give exact solution you are looking for! Log on to Pete's Performance Products
Herez the contacts......
Pete’s Performance Products
The International Hotel
P B No 3563
M G Road
Cochin 682035
KERALA
Office : +91 484 2382006 / 2380401
Fax : +91 484 2384755
Toll Free : 1800 425 8844
Technical Helpline : +91 9895088444
nikkibike is offline   Reply With Quote
Old 22nd April 2007, 13:48   #13
razor4077's Avatar
Thanked: 258 Times
How are the Spec after-market clutch kits? Anyone fitted it in their ride?
I was looking at the Stage 2 kit... seems apt for my needs. Any idea of the performance & price, and any alternatives?
razor4077 is offline   Reply With Quote
Old 22nd April 2007, 14:01   #14
nitrous's Avatar
Thanked: 285 Times
Guys, Even Ajmat had the same problem.
This seems to be inherent with a few petrol swifts. Manufacturing defect in the Clutch assembly, i guess.
@Karthik: Since SPEC clutch for the swift is available with Pete's at Cochin, get it.
Old 22nd April 2007, 14:22   #15
karthik247's Avatar
Thanked: 16 Times
Among the SPEC list, can someone recommend the type of clutch for my car which is only used for street driving. Should i look at Stage2, Stage2+ or go upto Stage3?
SPEC Clutch's
esteem engine (carburetor) needed asap nitroxx Shifting gears 1 12th April 2015 16:22
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Multi-Zone Home Audio Solution Needed ASAP manveet Gadgets, Computers & Software 6 22nd July 2007 15:33
Amby Needed!!! (asap!!) Rice_tuner Shifting gears 0 28th August 2005 11:55
