| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2006 Location: coimbatore,New Delhi
| I understand these terms as BHP- Horse power-says about the power of the engine. kgm- Torque- in physics text book as the rotating potential-in auto world the ability to cruise in top gears at slow speeds. CC- the volume of 'gas' consumed in one cycle in all cylinders. Now, consider Indica V2 TC 67 hp-13 kgm- 1405cc for 1T victa NA 68 hp- 12 kgm-1948cc-for 1.7T Since V2 TC and victa NA has the same power/torque range, (although different cc's) can a V2 TC engine work on the victa? How can the sumo victa NA move from standstill with an engine having less than V2TC's hp/kgm rating? spacio DI NA 60 hp- 16.2kgm- 1956cc A whopping 3L consumed, but why doesn't the spacio DI engine develop more hp/kgm? Indica V2 TC 67 hp-13 kgm-1405cc indigo TDI 62 hp-12.7 kgm-1405cc I suppose power and torque are inversely proportional for a given cc, but how does this is not true in indigo TDI when compared to V2 TC? tavera 80hp-19kgm-2499cc bolero 63.5hp-19.9kgm-2523cc both are UV's with DI engines, and both turbo charged, how could bolero's hp be so low? (both Kerb weight 1.6T) Also, toyota innova 102hp- 20.4 kgm-2494cc-1.5T tucson CRDi 112hp- 25 kgm-1991cc-1.6T Nissan X-trail 136hp- 32 kgm-2184cc-1.6T So what is the additional 500cc actually doing in toyota? |
| | #2 (permalink) |
| Senior - BHPian | it also depends on how they tune it. the diesel innova being sold in malaysia with the autobox develops 250nm of torque. (25kgm) and 115bhp. same engine tuned diffrently. as for the victa moving with less torque it also depends at what engine speed the torque is available. it must be much lower in the victa. |
| | #3 (permalink) | |||||
| Distinguished - BHPian ![]() | Quote:
If a car produces 13kgm (at the crank) has a 1st gear ratio of 3:1 and final drive ratio of 4:1, the total amount of torque reaching the wheels would be 13 x 3 x 4 = 156kgm (at the wheels). And if another car produces 20kgm (at the crank) has a 1st gear ratio of 2.6:1 and final drive ratio of 3:1, the total amount of torque reaching the wheels would be 20 x 2.6 x 3 = 156kgm. So whether your car produces 13kgm or 20kgm at the crank, they can be made to produce similar torque figures at the wheels. Quote:
When fuel is ignited at higher compression pressure, the force pushing the piston down is greater. This force multiplied by the stroke length gives you the torque produced at the crank. Higher force doesn't always mean higher torque, by using a longer stroke length, an engine with a lower compression pressure can achieve higher torque figs (but at lower rpms). However, there are many other factors like cylinder head, piston head, intake/exhaust etc that can affect the way an engine produces it's torque. Quote:
But like i mentioned earlier, the transmission plays a major role in deciding how much torque reaches the wheel. So, don't always go by what the engine specs say. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 24th April 2007 at 00:24. | |||||
| | #4 (permalink) |
| BHPian Join Date: Mar 2007 Location: Sindelfingen/Stuttgart-Germany
| Nice answer shanu, i agree with you. one more thing i would like to add, that engine specs offer these peak rated figures of BHP & torque in a certain operating band, under certain conditions. If two engines of same BHp & torque figures are there.But one which produces peak power at a lower RPM will lug more & accelerate early, & will need lower no of gear shifts to keep it in power band.They might have same Vehicle weight. Further as shanu described this engine output is further multiplied by drivetrain. So a slightly inferior spec engine mated with a better design gearbox & final drive may pull more than an engine appearing superior in specs o paper. Final better drive experince depends upon power available at drive wheels/weight.
__________________ Arun |
| | #6 (permalink) | |
| Quote:
ofcourse drive train plays a vital role in harnessing available power optimally.
__________________ Arun | |
| | #7 (permalink) | |
Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #8 (permalink) |
| So, in short the rpm at peak torque and the gearing ratio's all have to be considered as well..thanks shan2u. also the spacio's is 3000cc not 2000cc as mentioned.. Also regarding bolero, i read in overdrive(this month) that it pulls from way lower rpms(they say it can move even 2/3 rd gear from standstill!) |
| | #9 (permalink) | |
The specs you see in brochures and magazines don't say anything about the way a car performs. The OHC 1.5 is quicker than the OHC Vtec in low rpm rollons, even thought the Vtec has higher Torque and Power figs. Thats bcos max torque and power are achieved only when the high lift cam lobes are actuated. At low rpm, the engine uses it's low lift cam lobes that were designed for better fuel efficiency and not performance. The OHC 1.5 on the other hand uses the same cam profile throughout the revv band. This might give it better low end torque, but on the downside, it sacrifices top end power/torque. In simple, the OHC 1.5 jogs from idle to redline, while the OHC Vtec walks at low revvs (reducing consumption) and sprints at high rpm (increasing performance). There are some Vtec engines that can walk at low rpm, jog at mid rpm and sprint at high rpm (they're called 3 stage Vtecs). Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 24th April 2007 at 16:55. | |
| | #10 (permalink) |
| BHPian Join Date: Dec 2005 Location: SINGAPORE
| See following links for some more details: Physics behind car's movement Torque vs BHP? Relationship between CC and BHP |
| Thread Tools | |
Similar Threads | ||||
| AC related issue | abhibh | Technical Stuff | 2 | 4th March 2008 12:43 |
| Wireless Bandwidth and related queries | Venkatesh.C | Gadgets, Computers & Software | 5 | 18th October 2007 23:37 |
| alto related..... | thealtoman | Technical Stuff | 12 | 30th May 2007 21:29 |
| Zen related doubts | A S H V I N | Technical Stuff | 2 | 23rd April 2006 19:58 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
