Old 7th October 2008, 14:12   #121
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by Eddy View Post
What exactly is done in a clutch overhaul ?
IIRC, any or all of the following parts will be replaced
1. Clutch Plate
2. Pressure Plate
3. Bearing
4. Cover Assembly
5. Spring
Old 7th October 2008, 14:17   #122
nitrous's Avatar
Thanked: 285 Times
Who is the clutch plate vendor for the Swift diesel?
Old 7th October 2008, 14:32   #123
Correct me if I am wrong, but , is it not true that Swift Diesel clutch is different than Swift petrol ? Or it is exactly same?
Ajay_J is offline   Reply With Quote
Old 7th October 2008, 14:39   #124
Jaggu's Avatar
Thanked: 8,693 Times
Its different and hydrolic unit instead of a cable operated one, much more robust with minimal failure chances. Gearbox issued were reported but i dont recollect any regarding the clutch.
Old 7th October 2008, 14:41   #125
DieselFan's Avatar
Thanked: 234 Times
Swift D clutch is a much improved and stronger clutch as compared to the one on Swift P. Diesel has tremendous torque and needs much stronger clutch.
DieselFan is offline   Reply With Quote
Old 7th October 2008, 14:53   #126
risga's Avatar
Thanked: 46 Times
Write to Maruti with all details. The link is available on their web-site. Their service Engineer will speak to you and these guys are pretty reasonable. Best to retain the replaced components so that he can inspect them.
Usually, company would discourage clutch claims under warranty from the dealers. So these guys take the easy route and simply say company has refused.
If the part has failed pre-maturely without mis-handling, then it ought to be covered under warranty.
risga is offline   Reply With Quote
Old 7th October 2008, 15:19   #127
Eddy's Avatar
Thanked: 5,078 Times
Has the dealer given you the old parts back ?
Eddy is offline   Reply With Quote
Old 7th October 2008, 15:28   #128
ankit.jhamb's Avatar
i think writing to maruti and lodging a complaint would be the best solution to your problem,i have got clutch changed under warranty after writing to maruti.the dealer had flatly refused to change the clutch under warranty.
Since you have already paid may be after writing to maruti they may refund you the amount paid towards the clutch earlier
i am sure some of the TBHP members would be having contact details(email)of maruti regional office
ankit.jhamb is offline   Reply With Quote
Old 7th October 2008, 15:42   #129
sushanthr77's Avatar
Guys, I'll try to put up the detailed bill tomorrow. I am not sure whether the faulty clutch was returned to my dad after repair. I'll find this out later.
@ankit, thanks for the information. So we can claim clutch under warranty. How much time did the entire process take for you (filing a complaint and getting a response).
Guys, does any one of you have contact details of MUL regional office in Bangalore / Karnataka? I would like to proceed the way Ankit did and hope for a refund.
sushanthr77 is offline   Reply With Quote
Old 7th October 2008, 20:07   #130
yes,in my case i got a call from the service centre after my service/complaint and they told that now i can get my clutch replaced.
i had written to maruti that my car has only covered 15k kms in 1.5yrs and had all the service records.the clutch problem was mentioned from the first service and hence it must be replaced.
since my warranty was getting over,i got it replaced.not sure what was replaced.
the car above was a 2005 baleno.
but i am not sure now will you get a refund or not since you have already paid the amount.
Old 7th October 2008, 20:19   #131
SLK
SLK's Avatar
Thanked: 192 Times
MUL A.S.S is very ordinary afterall.
So it took you one full year to find that out!
Maruti's quality is not consistent at all. Owned 5 Maruti's so far, and had a frustrating first service expenience almost everytime. Not to mention, so was Honda's.
SLK is offline   Reply With Quote
Old 4th February 2009, 13:53   #132
adi99's Avatar
18K in my ODO and my clutch is 75% gone as per the service advisor. My car is in warranty but I do not want to go fight and get a similar clutch again. I am planning to go for an Exedy stage 1 clutch. What may be the cost here in Bangalore and where can I source it from?
adi99 is offline   Reply With Quote
Old 4th February 2009, 14:21   #133
vikram_d's Avatar
Thanked: 940 Times
Exedy stage 1 should cost you anywhere between 8 - 10k.
Old 4th February 2009, 15:57   #134
adi99's Avatar
Thanks Vikram. The green cars guy told me the clutch is weak. Where can I buy stage 1 here in Bangalore...any idea?
Old 4th February 2009, 16:08   #135
Fountainheader's Avatar
Vikram,
In layman's term, what is the difference between Stage 1 and Stage 2 Exedy clutches ?
Organic and Cermetallic is what the site says. I assume Stage 2 is more expensive than Stage 1.
Fountainheader is offline   Reply With Quote
Maruti using weak engine mounts? commonman Technical Stuff 4 12th January 2017 23:24
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Ikon 1.6 with weak clutch takes us to Darjeeling and a few forests of North Bengal. 1100D Travelogues 99 16th August 2009 10:43
Weak clutch on Esteem - Car speed not matching engine RPM gaurav.28ch Technical Stuff 2 26th November 2008 17:47
