| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Moderator ![]() | There are two members on this board (ajmat and Karthik) who had their swift clutch plates packing up within 5000kms The Autocar test mule Swift Petrol also packed the clutch by 14000 kms. I remember Maruti 800 used to have a weak clutch issue where slightly careless driving could pack the clutch plates around 25000kms. But with the swift the case seems to be worse. Also it appears that it may not be covered under warranty. To put things in perspective, nicely driven cars wether its the honda city or the Tata indica, your clutch lasts atleast 70,000kms. My own indica has seen very bad conditions for the clutch including hill driving etc., and at 80,000kms just the springs and bush kits for gear lever are showing their age, with clutch plates still in okay condition(no slippage etc.,). There are members with cars done 120K+ on original clutch. So swift owners, this question is for you. Are you facing clutch issues and plate slippage issues. If so did you get warranty coverage. Also there will be some owners done 20K+ without issues, you can also post your inputs.
__________________ .--- ..- ... - - .-- --- -- --- .-. . -.. .- -.-- ... - --- --. --- !! |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | It more likely is a case of QC than an engineering flaw. My Swift has approached 9k kms now and she'll be 1 yr old next month : I've had absolutely no problems with the clutch whatsoever. The clutch feels like it did when I drove her back after taking delivery.
__________________ If you lose your temper, you’ve lost the argument |
| | #3 (permalink) |
| Distinguished - BHPian ![]() | I think only the petrol has this problem as the diesel comes with a beefed up clutch as per MUL. Also the 2 test drive car's I've driven had completely worn out clutches even though they had done less than 10K kms. Infact on one test drive a colleague who had a santro and is not the best of the drivers actually messed up the clutch on an extended test drive. the car wasn't driveable and the clutch was totally stinking. I think there are more than 2 people on the forum who have complained of the Swift clutch.
__________________ \ / ][ |) `/ [_] "!" (\./) (o.o) ( X ) This is Bunny. Copy Bunny into your signature to help him achieve world domination. Last edited by vid6639 : 30th April 2007 at 15:11. |
| | #6 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| yup diesel has a different (bigger) gear box, atleast the oil that goes in is more ![]() and yes the diesel clutch is more weighted compared to petrol so obviously its again beefed up for additional torque
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #7 (permalink) |
| Distinguished - BHPian ![]() | Interesting topic, on saturday I was with a close friend & forum member Speedonline getting some ICE work done on his car. His Swift Petrol has done 26k and has severe clutch judder issues in city traffic, which I found quite surprising considering how less mileage the car had done & because he's a decent driver who doesn't ride the clutch. Even he was bothered a bit & is planning to take the car to the service centre to see if he can have it changed under warranty. It reminded me of the judder that my Santro had by the time I was about to sell it, difference being she had covered over 1L+ kms. As for other cars, my mother's Santro has done over 80k on the original clutch while my OHC has done 137k.
__________________ There is a very fine line between "Hobby" and "Mental Illness". |
| | #8 (permalink) |
| judder is common and the intensity varies from car to car in case of Petrol swift. my cousins car has a very minor one, especially when one tries to pull off a half clutch scenario and another friends has a great deal of shudder and is really a pain to drive in city
| | #9 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: Mumbai, India
| Say my Swift clutch wears out by 15k. And I would obviously not want another MUL clutch, and I go in for an aftermarket Exedy or Step, but street spec. No ceramics, no twin/tri plates, no excessive clamping loads. It would still give them an excuse to void any gearbox and flywheel related warranties, right? Maybe even engine warranty. So then it's a vicious circle. I keep buying MUL clutches every 15k. My Swift used to judder in traffic pretty early on. Then they did clutch play adjustment at Vitesse (Spectra is dumb, they didn't have a solution) and it's good now. Though it's only done 6.5k. I am already prepared for a bugger all clutch. And I would not like a MUL clutch again. |
| | #10 (permalink) |
| Team-BHP Moderator ![]() | Judder means issue with clutch. I am starting to get judder at 80K in my indica, and that too when the clutch has not been treated very well due to numerous hill drives where at one point of other the weak engine forces you to slip clutch. If the car has judder, it is a problem. As for speedonline's car I have seen how he drives. With his kind of driving I would expect the clutch to last 1L kms. However to the best of my knowledge, judder etc., is more a case of spring damage rather than clutch plate damage. Clutch plate worn out means slipping, i.e. engine revs increase but car does not go any faster. Please correct me if I am wrong.
| | #13 (permalink) |
| Senior - BHPian | my swift has done 25k+ and I also feel that the clutch is not so good.....it cannot transmit the whole power from the engine and slippage is a commmon issue .......it happens when one is doing a rabbit start.....so I avoid putting extra load on the clutch so as it might not fail....but till now no problem faces what so ever.....
__________________ If you are good at something do not do it for free !!!! |
| | #15 (permalink) |
| "...... If the vehicle has a mechanical or cable release system, check for free play at the clutch fork. The failure may have been caused by an incorrect adjustment. If the free-play adjustment was insufficient, the cover diaphragm or levers began to rise toward the bearing as the facing of the clutch disc began to wear. If the bearing was in continuous contact with the diaphragm, the clutch cover became partially engaged and allowed the clutch disc to slip, thus burning up the disc. If the problem is non-release on a vehicle with a cable system and the cable cannot be adjusted further, replace the cable. Clutch cables stretch and need to be inspected with every clutch replacement. Source: Automotive Clutch Problems? Find Your Answers Here! Me thinks, this clutch play issue could also be a major contributor. Like my erstwhile workshop Spectra motors could diagnose no issue with the clutch, inspite of my insisting that I felt there was an issue with the clutch, as it would judder in bumper-to-bumper traffic. Also my legs would hurt after a traffic stint, which I thought was strange, as I was used to driving my friend's M800 in traffic a lot. Vitesse SA immediately found an issue with the clutch play when I took it for second service, and it feels much better that service hence. My problem was rectified pretty early on, if I let it go on for longer, it will lead to clutch failure. Lets see how long mine lasts. Premature clutch replacement without warranty won't make my father happy, he always wanted to buy a Santro Xing, and I can be sure of being on the receiving end then. Last edited by ported_head : 30th April 2007 at 16:29. |
| Thread Tools | |
Similar Threads | ||||
| Maruti Suzuki Sx4 - Clutch problems | iridium | The Indian Car Scene!! | 1 | 29th February 2008 12:04 |
| Swift Diesel - Clutch Rattle at 2000km | P1tBull | Technical Stuff | 14 | 7th February 2008 10:11 |
| My Swift & Its Clutch | passioncool74 | Technical Stuff | 10 | 20th December 2007 16:16 |
| Upgraded clutch for swift ?? | khaadu75 | Technical Stuff | 13 | 9th November 2007 09:36 |
| Clutch Setting in the Swift | Optimus Prime | Technical Stuff | 4 | 27th July 2007 23:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
