Old 3rd August 2011, 18:58   #31
HIGHNOON's Avatar
Thanked: 56 Times
Default Re: Difference in diesel and petrol engine oils
@rki2007!
1) Since its your first oil change , you need to change as per the manufacturers specified interval . in this case 1 yr.
2) It may so happen that even though you have done 7500 as against say 15000km , one may have spent a lot of time engine running in traffic.
3) If the co. is charging 4000 rs for a little over 3 litre oil , it would be synthetic.
In which case you can run it for 15000 easy without changing.
4) If your original oil is a CI / CJ Grade 15w-40 , then you can stick to the same grade of oil , shouldnt cost you more than 1200 for the quantity required.
Or you'll end up again with a situation where a yr, has gone by and you may have done less than 10000km. So again the dilemna to change or not ?
HIGHNOON is offline   Reply With Quote
All about Diesel engine oils Tan1959 Technical Stuff 1729 29th November 2017 21:35
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
What the difference between a Diesel and Petrol engine?? bivin Technical Stuff 20 1st October 2009 14:26
