Old 26th June 2007, 13:21   #16
2fast4u's Avatar
with increase compression let us know how have you increased air / fuel mix and whats your cam profile now. otherwise its obvious it will knock.
fine tuning u made CR sound so simple
2fast4u is offline   Reply With Quote
Old 26th June 2007, 14:06   #17
Thanked: 20 Times
So finetuning will there be any benefit to a diesel engine.
swathyd is offline   Reply With Quote
Old 26th June 2007, 14:16   #18
Better utilisation of high compression without knocking is one of the major benefit of grooves......neither cam profile is changed nor porting to increase flow of air.....this project as usual was carried out with simple groove work...I think if this can be added together with grooves will make a much more difference....but simplicity of this technique lies in not touching any other parts like camshaft and valves.....i think its beneficial for common people this way only....
Here is a link showing excellent benefits in old Kinetic Honda...
SOMENDER-SINGH.com - Totally transformed !!
Enjoy....
finetuning is offline   Reply With Quote
Old 26th June 2007, 14:45   #19
heard in another forum that a guy actually rebore the engine from 150cc's to 195cc's.
Dunno how he managed but he has done it 3-4 times now easily.
mainak is offline   Reply With Quote
Old 26th June 2007, 15:29   #20
2fast4u's Avatar
Originally Posted by finetuning View Post
Enjoy....
so certainly u will have to use higher octane petrol right!!
increasing compression with stock internals would lead to reducing engine life. whats ur take on that.
Old 27th June 2007, 22:22   #21
With grooved engine head there is no need to use high octane fuel....normal octane rating is sufficient to pass on benefits......increasing Compression ratio with grooving is a novel approach of using high CR without detonation & without using high octane fuel......
Again increasing CR with grooves infact increases useful life on engine.I came to know about Esteem driven 3 lac Km after grooving by Somender Singh.
Bajaj Pulsar 150 Classic - Restoration & Modification Mr.Boss Motorbikes 59 3rd May 2018 18:55
Bajaj Pulsar 150/180 - Technical Specifications & Feature List bluevolt Motorbikes 1 4th October 2011 17:22
Pulsar 150 2010. Advantages/Disadvantages? EDIT - Booked a Honda CB Unicorn ramki067 Motorbikes 50 31st October 2010 18:17
'Grooving' my UNO 1.0 FIRE prateekswarup Modifications & Accessories 36 26th October 2010 18:06
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
