| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi All, Encouraged by the success of grooving in cars I decided to implement this wonderful technique on our bikes.I was thinking since long & finally grooved pulsar 150.The bike has been tranformed totally.Therer is excellent rise in initial torque.Bike is now vey very responsive.Pulsar 150 is having compression ratio of around 9.4:1 and we increased it further to nearly 10:1 by removing 0.4 mm metal from head surface.This bike is having two spark plug on opposite direction to enhance combustion.I grooved just opposite both plugs in the same manner as in cars.So there are two Grooves and were pointing towards plug area & having sharp edges on both sides. This job took nearly one day as we have to take head to other auto workshop for surface grinding. I have also applied another technique called "Edging".Its simply rounding the sharp corners on the surface of head so that there is better flow of gases.I have done this Edging with simple file.It helps better flow of air fuel mixture & exhaust gases in & out. We have taken photo by mobile phone & I m happy to share it. This Pulsar owner who is a frind of mine is extremly happy to see such a remarkabe transformation.FE is also on higher side but cant comment right now. ![]() ![]() ![]() Enjoy Last edited by finetuning : 3rd May 2007 at 20:43. |
| | #2 (permalink) |
| Senior - BHPian | Since you increased the compression alongwith the grooving how do you know that it was grooving that increased the performance, couldn't it have been due to the increase in compression? Increasing the compression alone would result in better low end torque, crisper throttle response and an increase in fuel economy (if the bike has not been upjetted). |
| | #4 (permalink) |
| I havent tried doing just grooves without increasing CR.......I think that for any such modification we need to support it by such means so that BANG in explosion can be better utilised.Performance gain is the combination of both.Grooves promots total burn.It will be interesting to know the effect of grooves without raising CR. What may be the method to check the rise in Torque & BHP in this bike? Enjoy. |
| | #8 (permalink) | |
| Quote:
Will post high resolution photo after 12th May...........I havent done anything to itake & outlet.........just grooving with increased compression and rounding of head surface after grinding work....there is remarkabe increase in torque..... Enjoy.. | |
| | #9 (permalink) | |
| BHPian Join Date: Dec 2006 Location: Mysore
| Quote:
AFAIK,Just grooving(w/o any header job) means fuel will burn better.But,the CR will go down the drain,it will start to feel underpowered to compensate that you need to do the head job to bump up the compression and get best of both world. Last edited by hemi : 5th May 2007 at 16:01. | |
| | #11 (permalink) |
| Hi, The grooved pulsar is V2....also we have to carry out tapet setting for increased compression & groove work.This is I think a must with grooving work.Bike is performing so well.Also FE is seen increasing but cant comment as not checked with 1 ltr bottle.Will share FE data soon.There is marked improvement in 2nd & 3rd gear.SO I assume low end tourque is on upside with this. Enjoy.... |
| | #13 (permalink) |
| Hi black12rr, Both bikes running great....pulsar is flying now.....photos that I shared are with mobile phone hence not very clear....next time I will share photos with digital camera....grooving is really a great option for performance enthusiast at no extra cost.....but the shape,position & size of grooves vary depending upon squish area & spark plug location....in case of pulsar having twin spark plug we made 2 grooves opposite each other where as in fiero only one...again cant comment on FE as no feedback.......so far I opted just a single groove per cylinder......there are reports that even 3 grooves per cylinders works well.......but again I prefer just single groove.....its a fun doing such projects successfully and sharing..... Enjoy..... |
| | #15 (permalink) |
| Hi Ananth, I think there is improvement in high RPM too......If we look at various links at somender's site we can find people getting benefited in racing too.....there is improvement in start to finish timing......concept of grooving is to create progressive turbulance which makes a total burn.High swirling promoted by groove together with increased compression gives excellent charge preperation which can maintain flame till exhaust valve opening........ |
| Thread Tools | |
Similar Threads | ||||
| Pulsar 150 for SALE | Elito11 | Shifting gears | 0 | 16th September 2007 19:47 |
| Apache / Pulsar 150/ Unicorn??? | BuRnT RuBbEr | Motorbikes | 18 | 17th August 2006 10:07 |
| Jetting For My Pulsar 150 | nikibusa | Motorbikes | 18 | 22nd March 2006 02:00 |
| pulsar 150 classic for sale | manaa45 | Shifting gears | 0 | 16th March 2006 16:37 |
| My Pulsar 150 vs Merc E220 | nikibusa | Street Experiences | 24 | 10th June 2005 11:06 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
