| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Dec 2006 Location: Kolkata
| Hi, I've a 2nd hand 2000 carb Zen. Recently after the last servicing i've started having problems with the AC. The AC works fine when the car is moving and is at higher RPM than the idling RPM (say at 20KM/hr and about 1200 RPM) but when i shift to neutral at traffic lights or even when i've to tackle the bumper to bumper kind of traffic and has to apply brake to bring the car to stop the engine stalls. The car has no problem without the AC. My idling RPM is about 750. So please suggest what to check for so that i'm not taken into ride by the service garage. Thanks, Arup |
| | #3 (permalink) |
| Newbie Join Date: Jun 2005 Location: Vadodara
| Arup, I had a similar problem. To add to the problem of stalling at lower speeds, also the car vibrates badly at idling speed. My recommendations: 1. I gave the car to Maruti authorised showroom for servicing & told them about this problem. It was rectified & now the pick-up is fine. It was to do with the Carburettor cleaning & engine tune-up. 2. Get the AC gas topped up. In case the gas is less, leads to inefficient cooling & one has to run the AC in higher setting. |
| | #4 (permalink) |
| BHPian | I had a similar problem. This was pin pointed to the AC vacuum pipe getting disconnected from the carburettor. The service center guys resolved by using a piece of binding wire to tie that pipe securely. They told me that it is called the AC diaphragm.
__________________ Oct 07 SX4 - ZXi 2002 Pulsar 180 1998 Zen LX -- SOLD Last edited by mtnrajdeep : 5th May 2007 at 12:11. |
| | #9 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| its behind the carb (firewall side), there will be tubes curled up down and sideways, inspect if all are attached proper. again if this is working fine check if the idle adjuster for ac is set correct, similar to regular idle you can turn the fat head screw for ac idle, though its tricky to access with air filter ON if you are complete novice to carbs then i suggest you learn all this from your mech this time around and then attempt ![]()
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #12 (permalink) |
| Newbie Join Date: May 2006 Location: Chennai
| Im experiencing a similar problem in my 6 months old santro. AC is good in high RPM but it stops blowing cold air when in idle. This has happend just after fitting a BRC LPG kit in my car. I dont no what could have gone wrong. Can anybody suggest a good AC mechanic in Chennai? Better if near Ashok Nagar. |
| | #13 (permalink) |
| BHPian | Im having a similar problem >> car getting switched off(gives a jerk when i pedal the clutch and goes off) when lowering gears but was able to switch on again , gave it to the mechanic he said ignition wires loose contact but now also i feel a jerk when i lower the gear. Zen MPFI 2003 with iridium spark plugs,k & n this problem existed since a month , i thought it was due to the dirty k & n and so i cleaned it that time itself, but in vain . fuel filter also replaced last week.. is this due to misfire ?? please help guys
__________________ Cheeers Yaswanth :) |
| | #14 (permalink) | |
| BHPian Join Date: Mar 2007 Location: Sindelfingen/Stuttgart-Germany
| Quote:
get your Idle mixture screw adjusted for correct RPM, make sure that engine is warm, before setting is done & without a/c on. After setting turn a/c on & make sure that, there should ne an increase in idle rpm automatically with a/c on.
__________________ Arun | |
| Thread Tools | |
Similar Threads | ||||
| Zen A/C condensor problem | rohit_dce | Technical Stuff | 3 | 16th November 2007 21:44 |
| Problem with Zen | nicejits | Technical Stuff | 8 | 9th August 2007 07:20 |
| Autocop Problem with my Zen | nicejits | Modifications & Accessories | 7 | 23rd June 2007 01:04 |
| Zen clutch problem | simran | Technical Stuff | 12 | 23rd September 2006 19:23 |
| a/c problem in zen! | hot_rod | Technical Stuff | 4 | 29th August 2005 22:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
its working all well again.
