Old 5th May 2007, 12:03   #1
scorpio118's Avatar
Question AC Fuel consumption...
I've recently upgraded myself from a M-800 non-AC to Wagon R LXi. I have one doubt. If the fuel consumption of AC is directly proportional to blower speed, or it consumes the same, irrespective of fan speed. Pl clarify
scorpio118 is offline   Reply With Quote
Old 5th May 2007, 14:11   #2
tsk1979's Avatar
Thanked: 16,422 Times
Blower speed has no direct contribution to fuel consumption, but with higher blower speed your AC will cut off less, and hence more fuel consumption but you will be hard pressed to notice the difference if you drive in extreme delhi heat in the day.
Old 5th May 2007, 14:26   #3
esteem_lover's Avatar
Thanked: 451 Times
Zilch. No connection. In our heat, there is practically no difference whatsoever as the AC will not get cut off at any point of time.
Old 5th May 2007, 14:49   #4
scorpio118's Avatar
It means, is it better to run AC full speed and then switch it off for some time, when it is chilled..
Old 5th May 2007, 16:47   #5
Jaggu's Avatar
Thanked: 8,694 Times
nope its better to leave the ac running in lower speed after using high speed for initial quick cooling, switching off and on will increase the FE on a hot summer day.
again lower blower speed means automatically the ac comp cuts off since grill temp reach max faster
Old 6th May 2007, 18:07   #6
gd1418's Avatar
Thanked: 656 Times
Depends..Delhi heat is much more than that of Madras. In my Scorpio the blower runs at its minimum setting and the compressor cuts off when the temp reaches it desired level. The 'kat, kat' of relay lets me know when the compressor switches off and on. And boy, it really cools..
Old 6th May 2007, 19:06   #7
sreenivass's Avatar
Even when the blower is at two my Petra chills well, I switch to blower 1 when its cool enough. With full load it is at 3 for some time then goes to 2.
sreenivass is offline   Reply With Quote
Old 6th May 2007, 21:59   #8
theMAG's Avatar
Thanked: 1,574 Times
Originally Posted by scorpio118 View Post
I'd like to think that the AC compressor load determines the fuel efficiency
idling fuel consumption and pollution passionpurple Technical Stuff 30 28th September 2011 14:38
high fuel consumption in indica dls morten Technical Stuff 3 17th August 2006 09:32
best  and worst fuel consumption figure speedsatya The Indian Car Scene 66 25th September 2005 22:40
Diesel beats Hybrid in Fuel consumption test amit The International Automotive Scene 3 7th September 2005 19:31
Fuel Consumption while standing still amitverma Technical Stuff 26 29th June 2005 10:26
