Thread Tools
Old 6th May 2007, 09:37   #1 (permalink)
sajo's Avatar
Default Strange noise from Indigo.
My dad's Indigo is producing a strange gurgling+scraping noise, but produced in metal (ie, not produced by any sort of fluid, but noise is similar). It can also be thought of as the sound a big heavy metal ball would make while rolling on another metal surface.
When taken to the A.S.S. , they replaced the power steering oil pipe, and also checked the entire system for leakage. Also, a faulty engine C-Mount was replaced. The power steering belt tension was checked for noise too. We got the car back yesterday, and for the first 10 kms, the noise had gone. But then it was back with a vengeance, louder than it appeared to be earlier. The car is going in again to the dealers on Monday (we called him immediately after the problem reappeared)... any tips/pointers on what to check/look out for ?
__________________
Its big, slow, thirsty and American - but love is strange!
sajo is offline   Reply With Quote
Old 6th May 2007, 09:43   #2 (permalink)
deep_bang's Avatar
Just thinking if it is the brakes. Does the sound increase when applying brake? I do remember something similar happenning on my Ford Taurus, but the sound was only when applying the brake.
deep_bang is offline   Reply With Quote
Old 6th May 2007, 09:45   #3 (permalink)
flipsyde's Avatar
i'm not too sure about this....... but when the rear wheel bearings on my M1000 packed up i ended up with similar noises. A sort of scraping/gurgling noise from the rear..... more prominent at higher speeds. Maybe you should ask them to check all 4 wheel bearings.
The gurus should be able help you out.
__________________
An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright
flipsyde is offline   Reply With Quote
Old 6th May 2007, 10:03   #4 (permalink)
sajo's Avatar
Thanks for the suggestion flipsyde. But you mentioned noise being more prominent at high speeds. But in my case, the noise is very loud and prominent at low speeds. Especially in stop and go traffic with bad roads. (ie, all of Pune).
__________________
Old 6th May 2007, 12:21   #5 (permalink)
rohan_fonseca's Avatar
If the sound is from the front get your struts checked.
rohan_fonseca is offline   Reply With Quote
Old 6th May 2007, 15:01   #6 (permalink)
tsk1979's Avatar
Does the noise change with engine revs?
__________________
Reclaiming.....!
Old 6th May 2007, 16:24   #7 (permalink)
sajo's Avatar
No, it remains constant irrespective of the engine revs.
@Deep_bang : Even I thought it might be the brakes, but then, its not produced at any particular instance. ie, not even all bad roads can produce it.. but 90% of them do, and so does 60% smooth tarmac. Surprisingly, the car remained very well behaved at the service station.
Also, the engine seems to lift itself slightly, when the car is put into gear and moved forward. Is this normal behaviour?
__________________
Old 6th May 2007, 22:57   #8 (permalink)
tsk1979's Avatar
One more question, does the noice come even when the car is not moving, i.e. just idling.
Is there any change in noise when AC is switched on etc.,
I am trying to figure out whether the noise is related to a part for which speed varies with respect to engine speed, or is it related to a part where the speed of the engine is not of any consequence.
__________________
Reclaiming.....!
Old 6th May 2007, 23:11   #9 (permalink)
sajo's Avatar
There is no noise during idling... also doesnt change when the AC is switched on or off. So I think its related to something for which the engine speed doesnt matter. Only motion does..and is more audible at low speeds. If I can, I will record the sound tomorrow and post it here.
__________________
Old 7th May 2007, 00:49   #10 (permalink)
Zappo's Avatar
Could it be something as simple as a mount coming loose and during motion scraping with some other body part, say wheels? Have you tried to bend down and inspect whether there is something that is hanging loose? Or maybe opened the bonnet and peered in to see if something loose is vibrating enough to make you suspect that it may start touching other parts during motion?
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 7th May 2007, 02:05   #11 (permalink)
tsk1979's Avatar
It most probably the silencer pipe. Indica/go exhaust pipes are tied by flimsy clamps which come off easily
__________________
Reclaiming.....!
Old 7th May 2007, 07:40   #12 (permalink)
sajo's Avatar
@Zappo : Been doing that every now and then. As I said in my first post, a suspect mount was replaced even.
Peering under the hood during idling reveals no loose or hanging parts, nor does the underbody.
__________________
Old 7th May 2007, 11:59   #13 (permalink)
deep_bang's Avatar
have you ruled out the possibility of bearings causing the problem?
Thread Tools
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Renault Logan 1.4 with CNG or Indigo LS (diesel) EDIT: Bought Indigo! panky12345 Sedans 28 29th February 2008 13:18
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
Strange noise from speakers Vivekphadnis Ask the Gurus 25 21st January 2006 23:12
Strange noise from 800 DCEite Technical Stuff 7 5th November 2005 10:33
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
