Old 6th May 2007, 19:02   #1
scorpio118's Avatar
Angry Strange Irritating gas in Wagon R
Recently bought Wagon R LXi, which is my first AC car. Earlier I was driving M-800 non AC. I have one strange observation, when I goes inside my parked car and starts it, its gives me a feel of some strange irritating gas / odour, that irritates my eyes and nose . This feeling vanishes off, as soon as I switch my AC on. It also comes, when I switch on the blower only, without AC.
What it could be? If this could be fumes of battery, or AC gas or what??
scorpio118 is offline   Reply With Quote
Old 7th May 2007, 02:12   #2
Zappo's Avatar
Thanked: 2,080 Times
Is it by any chance a Duo? That is the dual fuel version of WagonR...
Zappo is offline   Reply With Quote
Old 7th May 2007, 10:44   #3
n_aditya's Avatar
Thanked: 2,781 Times
Whatever it is get it checked ASAP. This could be LPG (assuming this is the duo model) or some other poisonous gas. Dont delay, just go to a reputed garage and have the issue investigated. Most important dont smoke in the car unless this issue is fixed.
Old 7th May 2007, 10:55   #4
DCEite's Avatar
Thanked: 607 Times
Sometimes the A/C can give a foul odour, just like the room a/c does. But i dont think it causes any irritation to eyes and nose. In any case, take it to M.A.S.S. should be able to handle it.
DCEite is offline   Reply With Quote
Old 7th May 2007, 11:42   #5
theMAG's Avatar
Thanked: 1,574 Times
Unless it smelt like the houselhold LPG odor - Methyl Mercaptan, I doubt its LPG - since your eyes/nose hurts. Check whether its leaking AC gas HFC134a or R134a - whichever comes in WagonR
Old 7th May 2007, 11:58   #6
scorpio118's Avatar
No, it's not duo. It's petrol car only. Wagon R LXi.
Old 11th May 2007, 14:02   #7
Thanked: 7 Times
Default Ditto here
I also experinced the same problem whenever blower is ON and AC is OFF. Did not really bother much in starting as only i felt the same and not my co-passengers. And now in summers AC is mostly ON.
Could you figure out the reason ?
Tanny
tanny is offline   Reply With Quote
Old 11th May 2007, 14:45   #8
scorpio118's Avatar
No, not yet... I've to visit MASS soon for this, but can't manage the time.
Old 2nd June 2007, 03:45   #9
ankitahuja's Avatar
Thanked: 46 Times
Me thinks it's due to weakness of the eyes. After using a computer or getting into a car parked in the sun.
Try letting in fresh air as suggested and then sit in the car. And yea, when only the blower is on (hot air) might cause the irritation again as the eyes need to keep cool. Try it, happened with me too for a long time till I discovered what's wrong!
Old 18th August 2010, 12:36   #10
WDM007's Avatar
Thanked: 12 Times
In my WagonR, when I swith ON the blower only for hot air, I assume the air comes from the engine-area, so there is some pungent smell of the engine/oil in the car.
What can be done to avoid this smell?
If the heater is kept ON for more time, all the car is filled with such nasty smell. Should I use two air freshners ?
Or the ducts or bonnet area need some cleaning ?
WDM007 is offline   Reply With Quote
Old 18th August 2010, 12:55   #11
Hashim's Avatar
Thanked: 32 Times
I think you are allergic to the odor of new car, many adhesives are used which gives that "new car" smell and sometimes causes eye irritation. Roll down your windows and start the blower for some time which will evacuate all these strong fumes and bring it to tolerable limit. After few months of use, these fumes will totally disappear.
Hashim is offline   Reply With Quote
Old 18th August 2010, 13:16   #12
WDM007's Avatar
Thanked: 12 Times
@ Hashim
May be time itself will solve the issue. But let me tell, this issue is only with the heating option. No issues otherwise.
PS: yes, I do love the scent of new car. Its great !
Old 18th August 2010, 13:44   #13
Hashim's Avatar
Thanked: 32 Times
Originally Posted by WDM007 View Post
@ Hashim
Actually I was replying to OP (scorpio118 post), sorry I should have quoted.
In heater mode air does not come from engine area, the engine coolant is taken as heating source and run thru coil inside dashboard and you get hot air. So its not oil/engine smell but something else. Get your heater system checked, there maybe some wire struck to the hoses which on heating will release this pungent fumes. Inhaling these fumes is not good for health.
Old 18th August 2010, 15:25   #14
ghpk's Avatar
Thanked: 193 Times
It can be your AC Air filter is having problem.
if you smell engine oil its certainly letting outside air into cabin when in re-circulation mode.
This air filter needs to be checked also ask M.A.S.S. to check A.C. pipes and seals for any leakage.
Even if the stale water like smell comes from A.C. (which is similar to home A.C. based where water clogged up, in lower tray), you should not be having engine oil smell having this oil smell certainly leads to assumption there's some Air Passing from your bonnet to cabin which should be fixed.
Old 18th August 2010, 17:08   #15
WDM007's Avatar
Thanked: 12 Times
Exactly like that smell !
Thanks for the suggestion.
This is the item to be highlighted in next servicing.
Most irritating car accessories!! akash_m Modifications & Accessories 419 28th December 2013 08:32
(Wagon R)ecreationally clicked - New Wagon R Scoop Pics EDIT: Brochure on pg 22 sidindica The Indian Car Scene 385 23rd April 2010 14:44
A minor but irritating issue after getting a new Exide battery finneyp Technical Stuff 11 13th February 2009 12:48
Most irritating co-driver habits? nishantgandhi The Indian Car Scene 5 1st February 2008 18:00
Wagon-R Vs. Estilo.. Is Wagon-R crowding the portfolio? nikhil3456 The Indian Car Scene 16 29th January 2007 23:34
