Thread Tools
Old 7th May 2007, 00:18   #1 (permalink)
Default 31 litres petrol in M-800-possible?
Hello,
I have a question for the experts, although nominal, but it has been in my mind for quite some time.
A couple of times, the person at the petrol pump managed to fill 31 litres of petrol into our car. The owners manual as well as the website says that the capacity is 28 litres. At the time of
refuelling, the fuel indicator had just touched E on the guage.
Is this possible or we were fooled by the pump guys?
AkMar is offline   Reply With Quote
Old 7th May 2007, 11:45   #2 (permalink)
Sankar's Avatar
It's possible if you fill the petrol till the brim. But it's a not a good idea because petrol evaporates and you also have to lug around the excess weight of the fuel.
Old 7th May 2007, 12:22   #3 (permalink)
navdeep's Avatar
Go for more than 28 litres if you are going on long drive else fill upto brim is not a good idea.
edit : brim = 1-2 litres less then brim but more than auto cut.
__________________
eXpect the uneXpected | Diesel For Men
navdeep is offline   Reply With Quote
Old 7th May 2007, 12:30   #4 (permalink)
Team-BHP Moderator
Jaggu's Avatar
whatever be the distance filling up to the brim is not recommended cos it goes against the principle on which the system was designed.
trust me mileage also will be better (marginally) if you stick to proper filling exercise, though am not sure if its coz of proper calculation or some other reason whereby the fuel might be wasted/un usable.
cheers
Jaggu
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 8th May 2007, 22:36   #5 (permalink)
scorpio118's Avatar
Filling to the brim is not a good idea at all. Petrol heats up quickly, and it need space to expand. Auto cut is designed to allow this space to petrol. You can go a little bit above auto-cut (to pay in round figure), but leave some space for petrol to expand, other wise it may create a very high pressure zone inside.
__________________
"It's darkest before the dawn..."
scorpio118 is offline   Reply With Quote
Old 9th May 2007, 18:04   #6 (permalink)
Petrol pump guys cheating you, sounds a more likely reason than anything else. Are you sure you checked for the '0' before they started filling? They sometimes also turn and twist the pipe to trap some petrol in it. Although, that would have made the difference of 750ml-1L at max; not 3 litres.
amu1983 is offline   Reply With Quote
Thread Tools
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 5 15th February 2008 12:13
Aveo 1.4 Petrol Base Variant or Swift ZX Petrol amitsethi100 Hatchbacks 23 27th October 2007 20:04
10+ litres, 500+bhp - Please welcome the new bride in my auto harem Steeroid The International Automotive Scene 39 2nd May 2006 14:27
Petrol & Petrol Additives askulkarni Technical Stuff 42 6th May 2005 09:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
