Thread Tools
Old 7th May 2007, 15:44   #1 (permalink)
Default Building a Tachometer for Swift LDi
I long to have a tachometer on my Swift LDi.
I have decent experience in building the electronics to get the numbers on LCD, but is there any point which will give the pulses ?
Vishnu
vishnugs is offline   Reply With Quote
Old 7th May 2007, 16:33   #2 (permalink)
Vishnu
I am not an electronics expert, but do you mean a tranducer point which will give pulses for each rotation of crankshaft?
If yes try somekind of motion sensor, on timing pully of crankshaft(i dont know if swift uses timing chain or belt), whatever may be the case belt or chain, the main crakshaft pully/sporket is the ideal location to indtall sensor.
What kind of sensor?...that you have to find out & tell me what you have used, may be some kind of magnetic counter may serve your purpose for transducer, but i dont have details for commercially available one.
Please do ltell me how you did it?
__________________
Arun
arunforu1 is offline   Reply With Quote
Old 7th May 2007, 16:48   #3 (permalink)
ajitkommini's Avatar
Rather than using a motion sensor, it would be better to measure the spark rate using something like an inductive tap on one of the spark plug cables. This is how most commercial tachometers work AFAIK.
ajitkommini is online now   Reply With Quote
Old 7th May 2007, 17:08   #4 (permalink)
elf
elf's Avatar
Originally Posted by ajitkommini View Post
... an inductive tap on one of the spark plug cables. ...
Err, ajit. Diesels don't have spark plugs or their attendant cables.
elf is offline   Reply With Quote
Old 7th May 2007, 17:18   #5 (permalink)
Right :-) sorry - not enough coffee in blood stream i guess
Old 7th May 2007, 17:23   #6 (permalink)
Team-BHP Moderator
Rtech's Avatar
Buy the Instrument cluster from the VDi. Take yours out. Fit that in. There should already be the necessary hook up for the tacho signal somewhere back there. There ya go. A stock looking instrument cluster.
Technically though I don't think this could be legal as you are essentially "clocking" you car, because your ODO will start from 0km again.
That's the basic. Maybe someone else with a better knowledge of the Swift electrics can assist you further.
Ofcourse, if you want to go the RICE way with a huge tacho that blocks 1/4 of the windscreen, thats possible too.
Old 7th May 2007, 17:58   #7 (permalink)
Tampering with the vehile in this fashion may invite a termination of warranty. So ask your dealer to do this work for you. That will save you from loosing warranty.
swathyd is offline   Reply With Quote
Old 7th May 2007, 19:23   #8 (permalink)
Sideways's Avatar
Tap the RPM signal fromthe ECU. You will need a wiring diagram of the ecu for this though to verify pin number.
__________________
He's Back
Sideways is offline   Reply With Quote
Old 7th May 2007, 19:26   #9 (permalink)
n_aditya's Avatar
I long to have a tachometer on my Swift.
Buy an aftermarket autoguage or autometer tacho. Various sizes and designs are available.
Old 7th May 2007, 19:39   #10 (permalink)
Ram
Ram's Avatar
In the days of the pre ECU diesels, a waveform was picked up from the alternator, waveshaped, scaled and fed to the tachometer.
Ram Rao
__________________
When you struggle for something and fail, that’s when you get Experience!
Ram is offline   Reply With Quote
Thread Tools
My new Swift LDI (woohoo!) jaibir Test-Drives & Initial Ownership Reports 40 17th March 2008 23:34
Swift LDI/Indica DLG T/Indigo LS gags12 Hatchbacks 17 16th November 2007 18:56
Swift VXI - Delivery delayed by 3 weeks, Do I buy Ford Ikon? EDIT : Bought Swift Ldi nikunj_cal Hatchbacks 142 6th September 2007 14:12
Indica Turbo or Swift LDi !!! speedemon Hatchbacks 55 29th July 2007 21:40
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
