Old 8th May 2007, 10:14   #1
Default dying problem in palio D
I own a palio diesel just a month old and done about 1200 kms.
i am facing a strange problem, sometimes when i am accelarating the engine seems to lag, as if about to die down for a couple of seconds and then everything becomes normal. it happens very erraticaly but today morning it happened again. what can be the reason for this. an electrical short circuit, because i got the music system installed from outside and i suspect a short in one of the speakers.
garychopper is offline   Reply With Quote
Old 8th May 2007, 11:00   #2
tsk1979's Avatar
Thanked: 16,420 Times
Air in the system. Check the hand plunger and related stuff for an air leak in your system. It could be bad diesel too, see if the problem goes away on a refuel? Inspection of the fuel filter will tell you whether the diesel was bad.
Old 8th May 2007, 11:05   #3
moralfibre's Avatar
Thanked: 6,532 Times
Hook it up to the Examiner and get it checked for any errors.
Old 8th May 2007, 11:23   #4
ghostrider4385's Avatar
Thanked: 7 Times
Keeps on happening to my friend's palio too. What he does to counter this problem is to start the car once, then switch it off, and start it again. It seems to work fine after that.
ghostrider4385 is offline   Reply With Quote
Old 8th May 2007, 12:19   #5
rohan_fonseca's Avatar
Am not a technical guy. Your car could be running on open loop after a morning cold start. It would need to obtain optimum temperature for the peak performance.
rohan_fonseca is offline   Reply With Quote
Help Saving The Dying Ice EDIT: Now dead S.I.N.G.H In-Car Entertainment 10 28th June 2011 10:04
sound car advice needed for my dying self esteem ! jeevan Modifications & Accessories 8 18th September 2009 04:13
Dying to get Leh'd in October - Opinions Welcome jp_in_hyd Route / Travel Queries 1 31st July 2009 21:13
What are the symptoms of a dying clutch plate on a bike xxaarraa Motorbikes 9 19th December 2008 21:11
A new born in a dying breed: Tiburon goes RWD Mpower The International Automotive Scene 32 9th August 2007 01:38
