| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hi guys, i had poster this earlier on different forums so some of you guys might be aware of this problem of mine. The issue is that the 1.6 engine misses a heartbeat every once in a while. I have been noticing this for some time now and i have seen that wenever this happens the rpm would be somewhere between the 1300-1500 mark. But the funny thing is that this does not happen every time i cross this rpm. so have not been really able to find out whether there is any specific pattern in which this occurs. The engine just misses a beat and there is a minor jerk after which everything is perfectly normal. I normally dont push the car much especially while driving in the city and i usually engage 5th as soon as i cross the 40-45km/hr mark. 4th gear comes at around the 30-35km/hr mark and the vehicle pulls along without any difficulty. On higways though i push her a little more and normally would be doing around 90-110km/hr. On highways since i am mostly at the higher rpm ranages, this issue is not that evident. So i assume that this problem does not happen at higher rpm ranges. Petrol used has always been the higher end versions like speed and xtra premium. Last week i also tried Power for the first time to know if it would make any difference. Last week connected the vehicle to the diagnostics unit at the A.S.S and found no errors on the ecu. As i had expected they said it mostly ahppens because of the fuel and added some additives to the petrol and asked me to check it out for a while. I am Yet to confirm if there has been any difference. But my logic tells me that its not anything to do with the fuel since i see the 'skip' is always at some particular rpm. I have got responses from users that i could be a faulty sensor, throttle body or an ecu. I dont want the "Authorised " tata guys to conduct their experiments on my vehicle. I talked to them but they did not know about any particular sensor that could be causing this problem. And since the ecu was not showing any errors they'll have to start checking it from one end. From all my "very good"(hmm!!) experience with the old TVS guys, i'm sure i dont want the tata guys to start it all over again and end up in spoiling the whole fun of driving. I would like to have a real good idea of all the aspects before i let them put their hands inside my engine bay. |
| | #2 (permalink) |
| Senior - BHPian | Hi gemithomas, this is normal behaviour and happens with my car too. I have driven a few GTX's which also exhibit this jerk. Someone told me that it happens when the ECU advances or retards fuel flow depending on the quality of fuel. Dont worry its not a major issue it happens in my car too. If you notice jerks which are very light and continuous and barely perceptible in traffic then its a throttle body issue and you must get it replaced in warranty. This is a problem with etchemkays car and he will be getting a new throttle body soon.
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) |
| | #3 (permalink) |
| Team-BHP Moderator ![]() | Faulty EGR valve? Could be stuck . Does you car stall too occasionally at low RPMs? Try getting your fuel filter checked too. These are the only two things I can think off which can cause this problem. It could be a clogged intake manifold too, but that will cause problems in pickup etc., too. I suggest you get these things checked in front of you at a workshop.
__________________ Reclaiming.....! |
| | #5 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| hope you are shifting atleast after 2 to 2.5 k, please understand that any car engine requires a min rpm to pull it, and more harm is caused if you try to unnecessarily load the engine in low revs than revving it a lil more. Assuming your gear shifts are normal, second check can be fuel filter that can be a culprit, if not proceed to spark plugs and wires (yes failure, loose connections can happen in brand new parts also) If all of the above is fine, then check the injectors, but in your case i really doubt this can be the issue. Finally if this is a part and parcel of fiats then you need to get in touch with the manufacture service manager for the territory.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #6 (permalink) |
| Team-BHP Moderator ![]() | Umm I disagree with all the above inputs given. Reason, no matter where you shift the engine should not miss. Ok you shift too early, you stall, or you knock, but missing. That means a misfire. Low RPM misfire is normally linked to EGR valve which is a troublesome piece of equipment in any car, be it petrol or diesel. If lots of Palio/Adventure petrols are having this, this could be a design issue. So if your car misfires, don't accept it as it is, fight. Back in 2003 whereabouts a friend of mine got a petrol indigo. Shifting to 4th at around 45kmph(recommended by Tata itself for FE) would result in a slight judder(not misfire). The acceleration at low RPMs was juddery. They kept on stalling him saying all cars have this, but he hung on, calling regional center and what not, and eventually his problem was solved. It was a common problem(something to do with ECU software) and was fixed in later batches. So that attitude "Common problem, happens in all cars" is not really healthy. gemi, one question to you, do you notice missing if you slow accelerate from idle to 1500rpm in neutral?
| | #7 (permalink) |
| what if it is engine shunting with low rpms and not missing as "termed"? can we over rule that?? ok do this check, at idle slowly rev the engine from 1000 to 2000, see if there is a "missing" anywhere, if it is really missing then it can be pin pointed to the dealer also this way.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 8th May 2007 at 11:54. |
| | #8 (permalink) |
| Team-BHP Moderator ![]() | It happens only sometimes, not always. If it was low rpm reason, he would feel the judders every time if shifting too low. 45kmph for 5th gear is okay in most petrol cars and even in diesels if you are not going up an incline.
| | #9 (permalink) | |
| Quote:
"minor jerk" is what makes me think that it might be low rpm shunt. And no for a heavy car like adventure even with a torqe engine like 1.6, 45 km/h for 5 th gear might be cutting it too close is what i feel.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #10 (permalink) |
| BHPian | Thanks a lot for all the very quick responses. I was always of the impression that uncessary revving was bad for the engine. The Fiat 1.6 engine pulls really well from very low as 1100-1200 rpm. I can quite easily shift up at as low as 1500-1600 rpm and yet the engine pulls so efficiently that i've never felt its under load. So in city i try shifting at these rpms as far as possible since i've heard that this would get me more F.E figures. I have never felt the need to go above 1800 rpm for an upshift on this engine. Could anyone confirm if its ok to shift at low rpm's if the engine does not show any signs of being over burdened. I have never felt the knock and the engine has never stalled. I have also tried accelerating in idle from 1000 to 2000 rpm just a few times but could not feel this 'missing'. Will do that some more times to get a feedback. What does the EGR valve do. Could you explain this. And if its a problem with this thing would it happen at a particular rpm. |
| | #11 (permalink) | |
| Team-BHP Moderator ![]() | Exhaust gas recirculation - Wikipedia, the free encyclopedia From the article Quote:
__________________ Reclaiming.....! | |
| | #12 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Minneapolis
| I agree to this ..I think clogged fuel filter, injectors etc could be a problem ... Does this happen when the fuel tank is at low level ? Quote:
Can an Intake manifold get clogged so much ? Airfilter wont let in so much dirt that intake manifold starts getting clogged .. IM not sure if EGR will cause such noticeable missing ? It may cause loss in power etc may even cause pinging and knocking as a main symptom,along with high engine temperatures also. Best way would be to see the exhaust emissions from a local testing facility, the NOX emissions should be high if it was an EGR issue. But these symptoms of engine missing dont sound like an EGR issue to me. Last edited by chetanhanda : 9th May 2007 at 06:54. | |
| | #13 (permalink) | ||
| Team-BHP Moderator ![]() | Quote:
His problem may be EGR valve open at idle while it is supposed to be off.
__________________ Reclaiming.....! | ||
| | #14 (permalink) |
| BHPian | It is not anyway related to the amount of fuel. I have checked that. Even when its on a full tank, this thing happens. Regarding a clogged intake manifold, Dont you think that this would affect the power delivery at all times. Logically i doubt if this would lead to a jerk at a particular rpm. Even a Fuel filter problem should not normally give me such a problem. Isnt it? Will a faulty EGR valve give erratic idling. In that case, my vehicle is very smooth at idle. I'v heard that the EGR comes on at aroung 1500rpm on the Fiat 1.6 engine. But there again my problem is slightly below this rpm. But just thinking. Could it be somehting likethe EGR opens up a bit early. Is there some sensor that is responsible for activating the EGR. Another thing that i have noticed is that i am most of the times on small slopes when this happens. Yet to confirm this. But i just have a feeling that it is happening more when i am on small slopes. Dont know whether it makes ay sense though!! |
| Thread Tools | |
Similar Threads | ||||
| Fiat Adventure - Last piece. | Arjun1010 | Sedans | 16 | 31st January 2008 14:14 |
| Fiat Adventure stopped?? | vinodbijlani | The Indian Car Scene!! | 1 | 12th August 2007 09:37 |
| Is the spirit of adventure/travel missing in us indians?? Or is it only me ? | Red Bull | Shifting gears | 8 | 10th January 2007 21:17 |
| Fiat Adventure wanted | raja_ys | Shifting gears | 0 | 1st November 2006 16:35 |
| Used Fiat Adventure / Weekend | Andre | Sedans | 4 | 3rd August 2006 22:23 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
