Old 21st July 2013, 22:41   #16
Thanked: 660 Times
Default Re: Minda-Huf central locking has swallowed its tongue!
Repairing/servicing remote is easy.!
just open it up. some has tiny screws and some plastic clips.
in case of clips use a small victorinox or any blade that you may have to pry open.
wash the rubber part and let it dry.
on the pcb, spray wd40, if you dont have it use AXE spray. Use an old tooth brush, be careful on the crystals as its terminals are very delicate.
Let it dry and reassemble it again. Simple.
PS: Do people want a DIY on it?
SirAlec is offline   (1) Thanks Reply With Quote
Old 22nd July 2013, 09:18   #17
Thanked: 94 Times
Originally Posted by joybhowmik View Post
Thanks JustCause. Exactly right.
Coordinates of shop please ?
It's in Lajpat Rai market. Shop no. 565. I guess it was called Amar Radios.
JustCause is offline   (1) Thanks Reply With Quote
Old 24th September 2015, 16:06   #18
Thanked: 82 Times
Hi there! I am reopening a very old thread here. My minda car auto locking system (that came with a neat silver body and 4 button remote, with black sides) has stopped working with a 10 year old Esteem car. And this happened out of the blue. The gizmo is fired up with electricity, so I believe it is a programming issue.
I can't find the minda remote programming manual (assuming I was given one) I would appreciate a few pointers here, to the manual around programming the minda remote or DIY post. Cheers
KomS_CarLog is offline   Reply With Quote
Old 5th November 2015, 15:07   #19
Thanked: 82 Times
Yipee! I cracked the code after some permutations. Here goes the step to match the remote (silver body with 4 buttons on a black background) to the MINDA car alarm system.
1. Turn ignition ON (from OFF position) and press both lock & un-lock buttons. Return to ignition OFF position
2. Turn ignition ON and OFF. Repeat this 4 times. On the 4th count, press both lock & un-lock buttons. At this point in time, the indicators will start flickering.
3. The remote is now ready to be paired with the car alarm unit. Press the lock button to complete pairing of the remote (repeat this for other remotes that need pairing)
3. Turn ignition ON th
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
Xenos / Autocop / Minda Central Locking keanu_reeves Modifications & Accessories 4 14th September 2007 04:56
Tips for Central Locking Systems and Bypassing mithun Technical Stuff 1 30th March 2006 11:37
